Lowering my car...Will wheel wells rub???
Old 06-06-2009 | 11:02 AM
joed996's Avatar
joed996 is infamous around these parts
Hi All,
Got my H&R springs item # 29466 for my 2004 996 C4s.
Currently have Champion RG5 19" rims with 295/30 19 ps2's
There is only 1 1/4" room from the top of the tire to the wheel well. The new springs should lower the car 1". Does anyone know if the tires will rub if i hit a bump? My stock 18" rims were 24" overall my new 19" rims are 25 3/4" This has changed the handling of the car that is why im lowering the car but i dont want it to rub against the wheel well. Any suggestions?? The springs are going in next weekend....Name:  rim1.jpg
Old 06-06-2009 | 11:36 AM
deckman's Avatar
Your wheels won't but your tires might
The rears will probably be fine, what size tires are on the front, and what are the offsets for both front and rear?
OT - what's going on with the wing(s) on your car. Is that two you have?
Old 06-06-2009 | 02:16 PM
usdmej's Avatar
usdmej is a jewel in the roughusdmej is a jewel in the roughusdmej is a jewel in the rough
chances are there will be rubbing issues
you could try increasing your camber, but that will cause your tires to wear out quicker
Old 06-06-2009 | 04:45 PM
deckman's Avatar
I don't know if 295/19's are wider than you should go. Mine is lowered with Pss9's and have 19" Champion RG5's. My guess is your wheels are the same size as mine. I have 245's up front and they rub a little when the wheels are locked. 235's would be better.The rears are 275's and that seems to be about right.
Old 06-06-2009 | 04:55 PM
joed996's Avatar
The rear wing is from Gemballa. Here is a picName:  gemballa 032.jpg
The upper wing adjusts manually up and down. The tt upper wing adjusts mechanically. I felt the car needed a wing and this was the one i liked best.
Old 06-06-2009 | 05:10 PM
deckman's Avatar
I missed you said you had a C4S. Sorry about that. Unless you have some odd offsets and super wide wheels, you should be fine.
Old 06-07-2009 | 01:29 AM
Houston996's Avatar
Houston996 is infamous around these parts
Deckman, you run 275's on 11'' wheels?
Old 06-07-2009 | 07:45 AM
joed996's Avatar
Thanks for the feed back. It may just make it the rears it will be tight someone suggested i can rollover the fender lips that may help. In the fronts I have a 2 1/2 inch space tire to wheel well which will be plenty of room. I'm guessing that because it is awd the front is jacked up alittle.
Just heard a sport pse exhaust with a k&n cold air filter big sound difference. May be looking to get one any advice pos or neg...
Old 06-07-2009 | 11:12 AM
deckman's Avatar
No. I misread the OP and thought he had a NB like me. I have 19x10 rears and run 275's. If I had 18x10 wheels I would run 295's. If I had a WB with 19" wheels I would run either 305 or 315's depending on offsets.
Old 06-07-2009 | 11:23 AM
speedyjp's Avatar
speedyjp is infamous around these parts
not to hijack OP's thread...
deckman... got any pics? i followed your upgrades but don't believe i've seen pics of your ride rocking the RG5's. mine and many other folks' favorites!
Old 06-07-2009 | 12:08 PM
deckman's Avatar
Speedy, I don't have that I've taken myself, but here is a link to a thread of a GTG last week that has a couple pics that include my car.
Joe, I really don't think you will have anything to worry about.
Old 06-07-2009 | 05:42 PM
usdmej's Avatar
my fault didn't realize you had a widebody. you shouldnt have to worry about rubbing with 295s
Old 06-11-2009 | 03:51 PM
speedyjp's Avatar
deckman... schwweeet! very nice with the champions.
Old 06-12-2009 | 11:56 AM
exophthalmos's Avatar
exophthalmos is infamous around these parts
joed966, let us know the result once you get them installed. post some pics too. GL.
john
Old 06-12-2009 | 12:11 PM
Brando's Avatar
Brando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud of
Cool
What size front tires are you running w/ the 295's?
Be careful matching up the rolling diameter Front to Rear or you will burn up the front diff.
315/25 & 235/35 are a near perfect match.
Depends on the wheel offsets.
I'm running 315/25/19 in the rear, lowered with JIC Coilovers and have no problem with clearance.
Quick Reply: Lowering my car...Will wheel wells rub???
