Brake Sensor Question
Old 07-01-2009 | 03:21 PM
Frög's Avatar
Frög is infamous around these parts
My brake sensor just turned on.. I can;t go to the shop just yet and I have an obligation and have to drive 300 miles away.. And back, so 600 miles total.. It will be mostly highway..
Can I do it without risking damage to my rotors? Driving slow and conservatively with minimum braking..
Old 07-01-2009 | 03:26 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
There is usually a little pad left even when the sensor wears through. It could also be a broken wire. How many miles on brakes? I would not go too long, you don't want metal on metal. If you have many miles on the car you will probably be replacing the rotors as part of the brake job. Good Luck!
Old 07-01-2009 | 03:32 PM
uberpoop's Avatar
uberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond repute
I got stuck in a similar situation... went a few hundred with the light on. My rotors were fine and still some meat on the pads, but I was very gentle for that few hundred miles.
Old 07-01-2009 | 03:34 PM
Frög's Avatar
I have 40k miles on the pads and rotors.. They were both replaced.. I drive VERY VERY hard.. But I feel like if its all highway, and I drive slow...
Old 07-01-2009 | 03:35 PM
Frög's Avatar
Ok great.. A few hundred with still meat on the pads.. I can do 600 highway and then first thing when I get back is brake job!
Old 07-01-2009 | 03:42 PM
JoelPirela's Avatar
JoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond reputeJoelPirela has a reputation beyond repute
yes, you can drive. Are you replacing the rotors? or just the pads?
Old 07-01-2009 | 07:28 PM
99C2's Avatar
99C2 is infamous around these parts
Brakes:
I just had the same thing at 33k miles and all I needed was Pads. Just last weekend in fact.
I did drive a few hundred miles with no problem.
99C2
Old 07-02-2009 | 12:55 AM
Frög's Avatar
I think just the pads.. The rotors have never been resurfaced, but considering the way I drive, I might need to replace both..
Old 07-02-2009 | 12:56 AM
Frög's Avatar
Thanks for all the help guys!!
Old 07-02-2009 | 04:10 AM
JoelPirela's Avatar
if you can feel a lip on the edge of the rotor, maybe it's a good time to replace them. Porsche brakes are the easiest to do.
joel
Old 07-02-2009 | 12:17 PM
CaRJoE0220's Avatar
CaRJoE0220 is infamous around these partsCaRJoE0220 is infamous around these parts
When mine came on I checked it and there is ALOT of brake left in the pad. Obviously not 5,000 miles or anything but its not like it turns on right before your brakes are ready to be scraping bare metal.
Old 07-02-2009 | 12:18 PM
CaRJoE0220's Avatar
While on the topic. I know the pads are super easy to replace but I feel I should get new rotors also. Is there any DIY's out there for rotors or is it pretty standard.
Old 07-02-2009 | 01:58 PM
Frög's Avatar
^ I would also like to know! I might do them myself, but idk..
Old 07-02-2009 | 02:24 PM
uberpoop's Avatar
from the look of things when I did my pads last month, once calipers are pulled aside, looks like rotors come right off... maybe a couple screws holding it on, but main force holding it is the lugs.
Old 07-02-2009 | 03:44 PM
JoelPirela's Avatar
2 phillips screws. that's all. Suncoast has the rotors real cheap now.
Quick Reply: Brake Sensor Question
