Zaino/ZFX problem
Zaino/ZFX problem
I finished buffing my side skirts and put Zaino Z2 on, but forgot to purchase and use the ZFX. Will there be a big difference if it is not used and can I still put multiple coats on?. If it is a problem how do I fix? Meant to post in detail section sorry.
Did you check the Zaino product info and FAQ's on their website?
the main purpose for ZFX is to:
1. allow for less than optimal surface preparation, and
2. allow faster application between coats.
No worries if you don't use it as long as you allow time for the polymer to cure before removed and next coat applied. Also do the Z-6 (or Z-8) between coats...I prefer Z-6 personally.
Is Z-6 Ultra Clean Gloss Enhancer Spray used every once in awhile or if I was say putting 2 coats in a row of Z2 I would put it on between doing the 2 coats to get higher gloss? I did not see a curing time data sheet for temp but the bottle said at least 15 mins and here in phoenix at 107 degrees I would think it is not long.
The pic is poor quality sorry but it did look deeper/darker then the door panel.
To buff, use a clean, dry 100% cotton, made in the USA, cloth buffing towel. The higher quality towel you use, the better your results. For most cars, you will need two towels to adequately buff off the Show Car Polish residue.
The final step is optional, but offers exceptional results. Give your car a final wipe down with Z-6 Ultra-Clean Gloss Enhancing Spray. Z-6 further enhances the Show Car Polish shine and picks up any remaining residue around emblems, seals and crevices.
To increase and improve your show car shine, apply one or more additional coats of Show Car Polish. Wait a minimum of 12 hours between coats, or use our new ZFX™ Flash Cure Accelerator Additive. When you add ZFX™ to your Show Car Polish you don’t need to use Z-1 Polish-LOK™, and there’s virtually no wait time required between coats of Z-2, Z-3 or Z-5 Show Car Polish.
I was at a high end car shop today and they suggested Z5/Z8 so I traded in my Z2 for Z5 it's used for dark color cars and Z8 for bling. They also invited me down when they do a detail so I can see the difference when using Zaino step products.
vogz
09-19-2015 01:02 PM
