Misha gt2m downforce
Old 10-29-2009 | 10:13 PM
Katmanz's Avatar
Katmanz is infamous around these parts
I did some searches didn't really find what I was looking for... I've got a 2004 996 c4s and will be putting on the misha gt2m wing pretty soon. Not sure if the wing will throw the car out of balance at higher speed and corners? Do I need to change my front lip/bumper to balance the car out? Or does the wing provide downforce for both front and back and nothing is required just like the OEM one that does it for both (front and back). Input would be much appreciated... If anyone has any real figures on the down force this wing provides both front and back would be great...
Old 10-30-2009 | 04:49 AM
FLY996's Avatar
FLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud of
Yes, it's a generally accepted practice that when you add a larger wing you also modify the front to reduce lift. I could be wrong but I don't believe any rear wing adds downforce to the front.
Old 10-30-2009 | 06:49 AM
GREERJ1's Avatar
GREERJ1 is infamous around these parts
The down force or lift of any wing, airplane or car, will be applied at the geometric center of the wing. If that center is aft of the rear wheels, the result will be a rotation about the rear axles. This will push the rear end down and lift the front. It is imperative that the aerodynamic forces be balanced in speeds above 75-80 mph. The higher the speed, the more crucial the loading becomes. The forces in play here go with the square of the velocity and can add quickly with a large wing and high speeds.
James Greer
Old 10-30-2009 | 07:45 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
Add a turbo lip or a techart bumper
But you should be okay unless you are driving 120+mph
Old 10-30-2009 | 11:38 AM
EB847's Avatar
EB847 is a jewel in the roughEB847 is a jewel in the roughEB847 is a jewel in the rough
"But you should be okay unless you are driving 120+mph"
agreed. i didn't notice any obvious difference after adding that wing (02c2). nor did i notice a difference after adding the gt3 splitter after that either (cheap alternative you should consider). should be noted i have not exceeded speeds over 120 on the track or.. ah hemm.. the street. i have never felt the front end "float" with any of the configurations. (stock, gt2m wing, gt2m wing plus gt3 splitter)
my guess is it would make a noticeable difference (with the stock front end) when you get up to 130-140+ and a very noticeable difference at 150+. if you're keeping it under 120, i wouldn't worry about it at all imo. especially with the added weight you have up front with the c4s.
oh and post pix after the install for us!!
Old 10-30-2009 | 12:17 PM
angldrkns9's Avatar
what are the gt3 splitters? pic please!
Old 10-30-2009 | 12:40 PM
Dervish's Avatar
Dervish is infamous around these parts
I've got the cup splitter attached to a stock front bumper and GT2M wing, feels very planted at 130-140 around the Ring and 175 on the (German) roads...
Old 10-30-2009 | 01:30 PM
EB847's Avatar
gt3: (see my avatar. purchased at local dealer for bout $230. was special order part) all you need to know found here: https://www.6speedonline.com/forums/...c2-bumper.html
installed on my car: http://EB847.homestead.com/files/PO
RSCHE/DSC_2977A.jpg
gt3 cup installed on dervish's car (a little larger): http://www.911uk.com/garage.php?mode=view_gallery_item&type=garage_gall ery&image_id=1401
http://www.911uk.com/garage.php?mode=view_gallery_item&type=garage_mod& image_id=621
a cup lip supplier (should be available thru dealer as well): http://www.carnewal-europe.com/main.htm
Old 10-30-2009 | 01:43 PM
angldrkns9's Avatar
got it! thanks! great look car you got there EB!
Old 10-30-2009 | 01:49 PM
Dervish's Avatar
Originally Posted by EB847
You Sir have good taste...
Old 10-30-2009 | 02:03 PM
EB847's Avatar
ditto! hehehe
Old 10-30-2009 | 02:37 PM
boochook's Avatar
boochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond reputeboochook has a reputation beyond repute
I've got the Misha on my C4S and love it, but I'm going to take it off most likely and go back to stock.......We see. If you're interested, let me know. Thanks.
Old 10-30-2009 | 03:23 PM
uberpoop's Avatar
uberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond reputeuberpoop has a reputation beyond repute
FWIW
On my car (2001 C4) with the gt2 style wing and no aero up front I did not like the feeling at about 80+... was too soft feeling on the steering. Not dangerous at all, but not how a p-car should feel.
Maybe it is not as noticeable on the 02+ cars?
Old 10-30-2009 | 09:32 PM
Katmanz's Avatar
Is this the lip you guys are talking about?
Old 10-30-2009 | 11:59 PM
Mdoog's Avatar
Mdoog is infamous around these parts
actually it is all in reference to the CG, not the axles
