Driver Side Heated Seat Not Working
When i press the Button the Red light comes on for Half a Second and then turns off... I Cheaked the Fuse, its good... Passenger Side works fine
Any Idea's?
Any Idea's?
I've got the same on mine... Had it checked by the local garage, they told me the heat element in the seat-back was broken... Here in Norway it would cost somewhere around $1000 to fix, including the work.
There are two heated cushion in each seat, one for the base and one for the back. The connectors for each are located under the seat. It is easy to test them with a voltage meter to see if the wires are broken. If they are the cushions are only a few hundred dollars at most.
Take a look at this site:
http://www.dennisvogel.com/heatedseats/index.html
I sued the instructions to install heated seats in my 996 Cab. It will show you the locations of the connections, how to remove the seats, etc. If you are a little handy you can fix the problem for a couple of hundred dollars.
Took it in to the Dealer today, The Seat Back Heating Element is Broken... Covered under CPO, Parts should be in Next Week
Also had the Oil Pressure Sensor Replaced under CPO... My OP Gauge Failed 3 times this Summer
Update
Had the work done Today, was covered under CPO...
Just incase someone else has the same issue. Backrest Element was "Defective"
Labor was 1.30 HR
Correction: RE and RE LF Seat. Remove Seat Back Cover. Dissassemble and Replace Seat Back Element in Cover
Parts:
1- 996-521-531-01 Backrest Cushion W/Heat $106 USD
1- 000-043-071-00 SECURING CLIPS $7.39
This is for the Comfort Seats
Labor was 1.30 HR
Parts:
mmm Im Planing on getting a 997 GT3 or Twin Turbo... No, CPO only come with Car Bought Through the Dealer... I havent really looked into Options, but there are some out there
Lowtush
01-25-2022 10:48 AM
GrantRR
06-28-2018 03:33 PM
