need auto electrical genius, alternator problem?
Your voltage is dropping because when the bass hits the amps are pulling more power than the alternator and stock battery can provide. Like was said before if you have a 600W system it prob is not really pushing 600w even at full tilt, but will be about a 20-30amp draw. Most vehicles come with a alternator that can cover what the stock vehicle needs, and adding to that can make the lights dim and other things when the voltage drops.
I would in on means purchase a capacitor for your vehicle. They are a complete waste of money when you look at it. You can get a smaller battery to run as a secondary battery for the extra power (pretty cheap and easy to do), or you could upgrade your starting battery to a AGM battery and prob cover all of the electrical draw.
Titan Motorsports (a supporting vendor of the site) carries XS Power batteries and a S1200 would work fine in your application, or one of the smaller 975 or 925 batteries. The S1200 would supply your audio system with 1500watts as a starting battery and would be smaller than the OEM battery for your vehicle. Your vehicle is a Group 54 battery and the S1200 would be a little smaller in size while providing a ton more power. It only weighs 33lbs. Like I said though you could get away with using the S975 (26lbs) or S925 (23lbs) as a starting battery and have plenty of power.
If you wanted to just add a small secondary battery you could run the D680 (15lbs) and have about 1000watts of power going to your system. These are AGM batteries so you do not have any worries of them leaking or corroding in your vehicle.
After you get the wires ran to your secondary battery you simply run your connections wires to from the secondary battery to the amp/s. The stock alternator will charge both batteries.
When you are not playing the system at full tilt the alternator will not have a problem charging the batteries, and when you are at full tilt the secondary battery will supply the extra power needed without demanding it all from the alternator.
There are high out put alternators out there for these applications, but with a system of that size I dont really think it is worth the money and trouble of upgrading the alternator. With a big system (2500 watts or more) then yes the alternator upgrade would be needed, but not in a 600W system.
Here is an example of a D680 installed under the seat in a F150 (I know this is a much bigger vehicle, but the same principals apply).
Followup questions for "more_speed"
Thanks! A few follow-up questions. Doesn't having two batteries present an extra load on the alternator though? With this configuration, should we be concerned with burning up the alternator?
marvelusmarvcus, hope you don't mind me asking these questions on your thread. Not trying to hijack.
With all that said. The secondary battery isn't putting more draw on the alternator, but basically supplying the missing power the alternator can not produce. During normal driving the alternator could charge up the secondary battery without being over worked.
cnebrask
09-17-2015 09:19 AM
EMC2
Cayenne 955/957
09-07-2015 05:20 PM
Yotam Refael
Cayenne
08-18-2015 03:03 PM
