Rear Wing Removal Process 996
Ok, I've looked and looked on the 6speed and Renntech sites and can't seem to find the instructions on how to remove the stock rear wing (retractable). Does anyone know of where I might be able to find the info?
Much appreciated!
Much appreciated!
wing removal...
The entire deck unit is held in by 4 bolts only. The wing unit inside the deck is held in place by a hinged mechanism contained inside the black housing that is attached to the bottom side of the deck lid. All of it is fairly easy to unbolt. But you will need to remove the wiring harness for the unit that is attached to the deck lid and replace it with an alternate harness to avoid the light that will illuminate on your dash. If you want directions, I'd start by looking on websites for aftermarket wing sellers. They usually post some instructions. Steve
The right tool.. an allen wrench? I couldnt find the instructions either and searched all the sites tonight before I started taking it all apart
What are you trying to accomplish, taking JUST the retractable part out or the entire decklid. The decklid is easy and quick, the retractable part takes longer but is pretty simple.
To take the lid off- two bolts on each side and your done.
To take the retractable part off only-
In my case, the wing I was installing went in the place of the lifting portion of the OEM lid. First, open the lid and look up at the bottom. There are "plugs" for the rubber that fills the gap between the wing and lid when open. They are held in by friction - to get them out, tap them from the bottom and catch the friction washers.
Next, there are 8 or so allen head bolts that hold the mechanisms and rams to the bottom of the lid. Take those all the way out.
Raise the wing with the switch and unplug the harness from the rear right of the engine bay. There are two small rods connecting the rams to the lid- held on by C-Clips. Take both off and remove the lid.
Now, everything should come loose from the top and the bottom of the lid. I took my fan off too, because now there is no wiring harness connecting it.
04-28-2022 12:38 AM
undefnd
16
08-26-2015 07:59 PM
