Engine Whine Hum noise at idle
Old 04-27-2010 | 11:14 AM
kinglenario's Avatar
kinglenario is infamous around these parts
hey guys, i searched for this but couldn't find anything. i have a 1999 c2 cab and have a couple noises.
at idle, when inside the car the engine has a whining noise that goes up with the engine revs. it sounds like a whiny fuel pump but goes up with revs so not sure...
also, when the car has been sitting in the rain and i start the car cold there is a squeaking noise that comes from the engine compartment for about 15 seconds then goes away. any ideas?
Old 04-27-2010 | 04:36 PM
jr1966's Avatar
jr1966 is just really nicejr1966 is just really nicejr1966 is just really nicejr1966 is just really nicejr1966 is just really nice
squeaking noise? possibly moisture on belts. seen that on mine but not 15 seconds long which was just due to moisture not coming from rain. checked my belts and they were fine.
I hear a very faint whining noise in my car too but I know it's just normal engine sound as it sounds similar to the whining noise that my other cars make.
Old 04-27-2010 | 09:56 PM
VIPR ETR's Avatar
VIPR ETR is infamous around these parts
Have you checked the alternator?
Old 04-28-2010 | 06:51 AM
it seems like a bad bearing in the alternator doesn't it. everything is working fine so maybe i shouldn't mess with it.
it's hard to hear the noise from the outside, but from the interior with the windows up you can really hear it.
has anyone had noisy fuel pump issues? isn't that in the tank though?
thanks
Old 10-10-2011 | 05:08 PM
Parkcity911's Avatar
Parkcity911 is infamous around these parts
My 2001 hums too. It goes away at about 1500 rpm's. Sounds normal enough, but I guess it could be "something" going out. My car "clicks mildly" on starts. Any ideas on what this might be. It does it for only about five full seconds. Is this normal dry pistons on a cold day / 50 deg F out.
Also, what does an IMS going out sound like? What to listen for? Thanks all.
Old 10-10-2011 | 07:04 PM
crazyed71's Avatar
crazyed71 is infamous around these parts
tr turning off your ac, mine wines a little.....
Old 10-12-2011 | 10:13 AM
Sosoomi1's Avatar
Sosoomi1 is a jewel in the roughSosoomi1 is a jewel in the roughSosoomi1 is a jewel in the rough
Pulley bearing??
Old 10-17-2011 | 04:53 PM
leapingtigr's Avatar
leapingtigr is infamous around these parts
could be a vacume line
nlakind
11-06-2015 10:15 AM
03EvoIII
09-21-2015 04:38 PM
turbotuner20v
09-11-2015 12:02 PM
docboy
09-06-2015 06:57 AM
Zero911
08-24-2015 06:51 PM
Quick Reply: Engine Whine Hum noise at idle
