where is the fuel pump???
Old 07-07-2010, 12:03 PM
Omarcoolguy's Avatar
Omarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant futureOmarcoolguy has a brilliant future
Originally Posted by Dharn55
996's don't have high pressure fuel pumps, that is part of the direct injection system on 997.2's, and is a known problem with them. This is not the source of Omar's problem.
im thinking its the crankshaft position sensor..what ya think ?? and i know how you love to take engines out lol...do you have any idea how to get to it ?
Old 07-07-2010, 07:25 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Omar - You don't usually need to drop the engine to do the sensor replacement. It is pretty accessible, located on the drivers side of the engine where the trans bolts to the engine. If you have a lift or jack the car up you can get at it. The exception to this is if the sensor is corroded in. On may car, which had seen 9+ Chicago winters, when the sensor went bad (after I had the engine out for the intermix repair and had reinstalled it) the sensor was completely corroded in place. Tried to pull it out, pry it out, drill it out, no way. Finally had to drop the engine, take off the trans and beat the thing out with a hammer, and the sensor body is plastic. Amazing what all that road salt will do.
Old 07-08-2010, 10:08 PM
so your saying you want to help me out then ....
Old 07-09-2010, 03:23 AM
Dharn55's Avatar
The sender is part number 98660611202. About the best price I have found is at Vertex Auto for $109. Get one and if you have a lift I will be happy to show you (and the girls) how to change it.
Old 07-10-2010, 11:05 PM
thanks i just ordered it , that was the best price..the cheapest i saw was 130
do i need a lift?
Old 07-11-2010, 08:42 AM
Dharn55's Avatar
You can do it on jack stands but a lift sure makes it easier.
Old 07-11-2010, 07:30 PM
Thumbs up
ill let u know how it goes....i think ill be ok ! lol
Old 07-18-2010, 09:55 PM
Thumbs up
UPDATE... WAS THE CRANKSHAFT POSITION SENSOR ...pretty easy fix...running great !!
Old 07-18-2010, 10:05 PM
GT3 Chuck's Avatar
Administrator
glad to hear it was an easy fix
adnanm3
11-22-2023 02:43 AM
pwdrhound
09-13-2016 10:44 AM
XLR82XS
10-05-2015 07:02 AM
Quick Reply: where is the fuel pump???
