Installed LED Tail lights + PowderCoated Exhaust Tips
Old 12-07-2010 | 12:32 AM
FLY996's Avatar
FLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud of
Originally Posted by Tarek307
Any updates fly?
still waiting for shipment...should install by this weekend...
Old 12-07-2010 | 08:18 AM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
looks good.....
Old 12-07-2010 | 05:47 PM
FLY996's Avatar
Box arrived today!
Nicely packaged but...
Replacement ordered...
Old 12-07-2010 | 10:20 PM
philooo's Avatar
philooo is infamous around these parts
I feel your pain
http://forums.rennlist.com/rennforum...27-post30.html
should get my second set today..finger's crossed
Old 12-07-2010 | 10:26 PM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
That seems to be the major issue with these things... just a lucky draw if you get a good set. Think I heard someone ended up with a third and fourth set before it was sorted.
Do you have to send them back?
Cheers
Aaron
Old 12-07-2010 | 11:26 PM
FLY996's Avatar
Cheers
Aaron
Yes. Amazon provides a pre-paid return shipping label and cross ships the replacements...I'll keep returning them until I get a good set...
1.
Old 12-08-2010 | 07:31 AM
Panteralkn's Avatar
Panteralkn is infamous around these parts
Cheers
Aaron
I went through 3 sets until I got a good driver side and passenger side. What a pita -- although working thru amazon was pretty easy and low stress. Just took longer than I wanted to get them up and running.
Old 12-08-2010 | 07:45 AM
Wheelman's Avatar
Wheelman is infamous around these parts
Tarek307,
does your vehicle have PSM? I was one of the original buyers when these came out and besides the hyperblinking issue...my PSM and ABS lights lit up. Probably due to the voltage coming in but wanted to check with you if your car has it and any issues with PSM.
Old 12-08-2010 | 12:09 PM
Panteralkn's Avatar
Originally Posted by Wheelman
Tarek307,
mine does - and along with the flasher change - i had to do the resistor modification as well. Really pretty simple.
Old 12-08-2010 | 11:12 PM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
Tarek307,
Yes i have PSM and its a 2002- again as i mentioned you DONT NEED RESISTORS or anything JUST THAT 1 FLASHER RELAY- i posted its Part # and where to get it- you just take your old one out, plug this one in and thats it! no issues!
1.
That sucks! but oh well, its worth it, i guess i'm lucky mine came perfect the first time!
Old 12-09-2010 | 12:10 PM
Panteralkn's Avatar
Tarek - do you have the litronics? i wonder if that is the reason i needed the resistors....
Old 12-09-2010 | 01:02 PM
Tarek307's Avatar
Litronics as in the Turbo headlights they changed to in 2002 then yes...the xenons right? yup thats what i got!
Old 12-09-2010 | 01:06 PM
Panteralkn's Avatar
yeah the Xenon's
well I'm stumped - i don't know why i needed the resistors. But without them i got a brake light error and it turned off my PSM.
Old 12-10-2010 | 02:23 PM
FLY996's Avatar
I received my second set yesterday...no broken pieces and they look great. I did the install including the flasher module. The lower LED's work but the upper LED section on both do not light up.????
Old 12-10-2010 | 03:21 PM
philooo's Avatar
So I made all my testing by turning ON and OFF the light switch and all was fine..
But now that I test it with the ignition key in and ready to start (or if the engine is running), my third stop light is turning on ....
Note1: that I have a LED third brake light kit installed, so I wonder if that picks up some low power that is usually in the system but not enough to lit up the blb version or... if I have another short somewhere
Note2: the picture is taken with the lgiht switch on, and the key in the on position. But I do NOT have my foot on the brake pedal.. I am taking the picture
