Installed LED Tail lights + PowderCoated Exhaust Tips
#46
hmm wonder if that it then! i also have the fixed wing! all i needed was the relay and thats it!
#47
HI
I have a 99 carrera..2 questions:
How do i update the headlights to give it the 2004 look..Assuming the 997 look is impossible.
Do you guys knows where i can get a pair of tail lights (LEDS) at the best price
#50
There are 1 MILLIONNNNNNNNNNN posts just in this thread telling you AMAZON.com is where many got! Search man, SEARCH!!!
#51
No its very hard to take a pic.. just look to the left of the clutch on the top row- its between a few tall relays, on the top row, turn on your Turn signal and you WILL FEEL IT CLICKING it will be very obvious, you can feel it! just pull out - i think it says 93 on it- and you will just replace with the one your getting very simple!
To install, you need to push your driver seat back as far as it will go, get on your back, and contort yourself under the steering wheel. The relays are located high behind and above the fuse box, just to the left of the dead pedal.
Put your indicator on and you will feel the relay clicking - in my case, it was labelled "191" up high and center. Wiggle it out, press in the new one, and you're done.
Old/OEM on left, new LED [CF13GL-02] on right.
#52
Ok the lights work well...but the fog lamp section doeant work..so both sides direcrly under the reverse lamps dont do anything.
Question can I splice off my break/parking lights and put a led bulb in that non working slots
slicky rick
10-19-2019 02:05 PM
joseph_number1
07-19-2018 05:45 PM
