temperature light blinking HELP??
i am unsure what to check next.
my temp light has been blinking for a few months now. the temp is fine unless i let the car sit. when sitting the temp goes above normal. when driving everything is fine.
when i first checked the coolant, a few months ago, it was full. i recently checked it and it was a little low, filled it up, light still blinking.
thought it might be a bad cooling fan, but hear them all come on and have seen the engine fan working.
have smelled coolant after driving car for a while.
took the car to a mechanic, he did a pressure test, said no leaks.
any ideas?
any ideas?
I thought flashing light was low coolant. Might have air in the system. You might try driving it for a day with the burp valve open or parking it nose down with burp valve open. I would also check to see if the oil looks milky and for any coolant leaks. Coolant tanks have been known to crack too.
other thoughts if your thermostat is not opening all the way this could also create a problem, or if radiator fan is not kicking on.
not sure where the bleeder is on that car but find it crack it open and add coolant until it comes out..to make sure its full.
once you know its filled let it idle ..keep a eye on the temp and listen to see if the fan kicks
i have been running the car with the burp valve open. i have had to add water a few times.
it seems that when the car sits, everything is fine.
when i drive the car for a while, a small amount of water needs to be added. when i open the tank for this, there is always a blast of built up air.
it seems like air is getting into the system, and water is getting out. i had a pressure test done, but no leaks.
is it possible that somehow the leak opens up only when the car is operating? i think the pressure test is done with the car sitting and off?
what should i do next?
Do you see any coolant leaking anywhere? My water pump went out of no where. Drove it fine one day parked it in a lot came outside and had a pool of coolant on the ground. What i did to figure it out was I took the coolant tank cap off put a rubber cap on it with a hole and with an air hose put alittle pressure in it and it was east to tell where the leak was. I also had an issue at another time with a small pin hole in one of the front radiators. I suggest taking the front bumper off and checking both of them and all the hoses in fittings in that area. Good luck man.
UPDATE
drove the car around the other day. when i pulled up and parked the car, i saw smoke coming from the engine.
popped the hood and saw coolant on the left side. still have no idea where the leak is. have not driven the car since.
i am thinking about taking it back to the shop for another pressure test.
any thoughts?
and thanks for all the help guys
any thoughts?
Your coolant tank is cracked and is leaking. Look under the drivers side tail pipe and see if it shows sign of stains from the slight drip that is leaking along the muffler and making its way down to the tailpipe. My light was blinking on and I was adding coolant too. My leak was boiling off when it hit the HOT muffler and tailpipe and never made it to the ground until one day when it was parked and I found a puddle under the car.
THE COOLANT TANK!!!!
thanks guys
what is the best angle to look for the leak? do i need to jack the car and get underneath? i tried laying on the ground and looking but there is not much clearance.
Tank cracks on the bottom/backside. Can't really see it. If there is coolant residue on the frame rail below it, the tank is bad. If the tank is yellow.....you can pretty much bet it is cracked. Tank should be white.
Replace the tank and also change to the updated black style tank cap. Throw the blue one away.
GSR Autosport
08-26-2015 05:20 PM
PelicanParts.com
08-26-2015 04:25 PM
PelicanParts.com
08-26-2015 04:24 PM
ECS Tuning - VW
08-21-2015 09:11 AM
