I have an oil leak - PICS
Drivers side next to the rear tire.
Uploaded with ImageShack.us
Does it drip all the time or just after you take the car out? I had an issue with leaking oil but it only leaked when the car was above 3000rpm. It turned out to be the spark plug tubes. It was pretty easy to change them all and was about $200 in parts and tools. There is a good write up on Renntech.org about it.
breather bellows (AOS) or valve cover sealant/ cam plug. Reseal the cover, replace the cam plugs and the bellows. Change oil too.
Depending on engine the spark plug tubes some times leak...
Jayster.
Jayster.
The Oil seperator is a good one, also there is a breather line that is prone to leaking.
http://www.porsche.com/all/media/pdf...SA_KATALOG.pdf
illistration 104-10, give you an idea of what it is.
inamjetdriver
08-31-2015 08:01 PM
