02 996 right side engine knocks at idle
Old 05-30-2011 | 10:37 PM
BC911's Avatar
BC911 is infamous around these parts
Hello everyone, just bought my first 02 911 convertable with 85K miles on it. for the last month i been hearing a knocking sounds on the lower right side of engine. cars still runs great! and it only happens at idle and when engine is warmed. in the moring when idle is at 1000 rmp, there is no knocking sound. just last week i had a check engine light p0430 (right cat?)... I cleared it with a scanner and so far 1 week driving it has not come back.
possible valve lifters?? but sound is coming from underneath right side...
I also noticed the right side exhause pipe is getting more black vs the left pipe which still looks very clean. anyone has similar problem or any suggestions would be greatly appreciated!! thanks
Old 02-14-2014 | 06:35 PM
dailydriver's Avatar
dailydriver is infamous around these parts
Digging up an old thread in the hopes the OP will reply.
I am experiencing very similar behavior. A few weeks ago I started hearing a hollow infrequent knock that has become more regular and noticeable over time. 2 weeks ago the car threw a CEL for a misfire on cylinder 1, which was attributed to a cracked ignition coil that got wet during our FL monsoon.
I replaced all of the plugs and coils (as I just crossed 60k miles) and the car has run great for 2 weeks. Today on the ride home I threw another CEL with code P0430.
The most likely suspects are a bad Cat, or O2 sensor, but I am unclear if either of these would produce the knock I am hearing underneath the car. Hopefully the OP or someone else can shed some insight here...
Old 02-14-2014 | 08:21 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
too lazy to look up the code but if your cat is loose...it'll trigger code and you can hear a gradually increasing metallic/knocking noise
Old 02-15-2014 | 12:36 AM
Dish911's Avatar
Dish911 is infamous around these parts
MY 99 had an knocking at idle, but I discovered the previous owner put on a lightweight fly wheel and that was my issue, I initially thought cats but when I Pushed in the clutch at idle and the knocking went way. It's a common mod on P-cars but when I changed the clutch I went back to the correct fly wheel and no knocking since. Good luck on sourcing the issue...
Old 02-15-2014 | 08:05 AM
RDykmans's Avatar
RDykmans is infamous around these parts
04-28-2022 12:38 AM
03EvoIII
09-21-2015 04:38 PM
turbotuner20v
09-11-2015 12:02 PM
vr6tee
08-29-2015 03:52 AM
Quick Reply: 02 996 right side engine knocks at idle
