Psm/Abs Help please
Old 04-06-2012 | 09:54 PM
karimhamir's Avatar
karimhamir is infamous around these parts
Originally Posted by k9racer
do you have a 996 turbo? I changed my intake to the evom v flow intake, silicone hoses, ap diverters, ap race plenum. I noticed that the maf/abs light came on. I ran a check using my durametric cable and cleared the code. Then i tested the car again, then after a short boost run, the light came on again. I looked again under the hood and double checked the hose connections just to make sure there were no leaks. I noticed a small vacuum line was off underneath the intake y collector right before the throttle body. After connection i reconnected the line and no light.
when you noticed the small vacum was line was off how did you notice it was there a hissing sound? I am experiencing the same issue
Old 04-07-2012 | 06:53 AM
JB Lifeguard's Avatar
JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !JB Lifeguard Is a GOD !
I had same problem. Check the clock spring the steering sensor behind the 4 stalk control unit behind the steering wheel. Good luck.
enoyskt
04-13-2013 10:55 AM
Dan Babb
01-21-2013 04:08 PM
XLR82XS
05-31-2012 07:31 AM
jleeev
02-02-2010 02:16 PM
M3CAB
09-16-2004 08:15 AM
Quick Reply: Psm/Abs Help please
