Key fob stopped working (I replaced the key battery)
Old 08-02-2011 | 09:40 AM
Slider's Avatar
You can remove it or not, I don't think it matters.
Old 08-02-2011 | 10:22 AM
citybythebay's Avatar
citybythebay is infamous around these parts
I removed it and pressed the button but there was no response. The light on the fob blinked when I pressed it but it did not do anything . Is this key toast? I have another spare key and both are not working although I tested only one.
Old 08-02-2011 | 03:48 PM
Slider's Avatar
When it blinks, does it blink real fast as long as you hold the button - or does it only blink about once per second. I had a fob go toast on me for no reason. It started blinking once per second instead of fast. Fast is good - slow is bad.
Old 08-03-2011 | 09:28 AM
It blinks several times, not just once. The spare fob also does the same..
Old 08-03-2011 | 10:29 AM
alpine003's Avatar
It seems everyone is talking about the key(s) but no one has mentioned the fuse(s) or alarm module which can be at fault as well. Everyone that is having issues, do you have an aftermarket radio installed?
Old 08-03-2011 | 01:46 PM
No, I don't have an aftermarket radio. I have the original porsche radio.
Old 08-03-2011 | 02:45 PM
Slider's Avatar
For people who have one working FOB and one not, it is easy to rule out the fuses and alarm module...
Old 08-03-2011 | 06:21 PM
Slider's Avatar
Multiple blinks are good. If both fobs worked before and now do not, you should check the fuses for the remote entry system - does the security light (on the dash) blink when the doors are locked? If everything checks out, you are left with having to go to the dealer for diagnostics.
Old 08-04-2011 | 08:39 AM
alpine003's Avatar
Durametric should be able to detect alarm fault codes if you know anyone that has one. Might be worth a try first.
Also check under driver's seat for any dampness or loose wires.
Old 08-07-2011 | 11:23 PM
nosatalian's Avatar
nosatalian is infamous around these parts
Yeah, I would suspect the alarm system, not the key at this point
Old 08-08-2011 | 12:07 AM
producerjohn's Avatar
producerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud ofproducerjohn has much to be proud of
Sorry, but the same thing happened to me. You'r fob is toast.
Old 08-08-2011 | 10:02 AM
Chances are I'll just use my fob's manually to lock/unlock the car...bummer but..
Old 08-16-2011 | 04:21 AM
Nine_Eleven's Avatar
Nine_Eleven is infamous around these parts
Damn this sucks.
I hate using the key to unlock and lock.
Old 08-16-2011 | 06:04 AM
mj31's Avatar
mj31 is infamous around these partsmj31 is infamous around these parts
I'm having the same problem with my keys and i have a after market radio. So what should i check for now?
Quick Reply: Key fob stopped working (I replaced the key battery)
