Key fob stopped working (I replaced the key battery)
(996) Suddenly my key stop working, I changed the battery. It would light up/blink (red LED) but doesn't unlock or lock. I have to put the key in to unlock/lock.
What could it be? Transmitter? Reprogram?
possibly dead key. happens, happend to me
Fob probably died, get a new fob from Sunset ~$100 and take the blade from the old key and put it in the new fob. Then you need to take all your keys to porsche dealer to reprogram that one. I just went through this and it cost me $55 at pioneer porsche (PCA discount)
There are two ways the key can be affected... If the unlock button is activated 256 time while out of range of the car, it will de-activate itself. To re-activate, all you have to do is use that key to start the car and activate the transmitter (unlock) within 6 seconds of stopping the engine. Now, here's the thing... If the unlock is activated 1000 times while out of range of the car (like say, sitting on the keyfob in your pocket for 5 minutes), even an act of god will not re-activate the key and you will need to replace the radio transmitter.
There are two parts to the key - the "pill" or ignition transponder and the radio transmitter used to unlock the car. They are not linked - one can be replaced without replacing the other.
Go ahead - ask me how I know all this stuff...
carlsen porsche charged me $450 for a whole new key plus programming.
i have a spare key that works for my 996. if you find a way to reprogram it to your car, you can have it for cheap.
I just gave that a try, and now the other key doesnt work, in fact nothing works now.
To re-program - start the car with the key in question, then turn off the car and press the lock button on the keyfob within 6 seconds. If that doesn't fix it, you are wasting your time at the dealer - he won't be able to fix it either (assuming you have another key that is still working properly).
If you can start the car, the transponder is working. If you can't unlock your doors with the keyfob (and it is blinking), then your radio transmitter has de-activated itself.
