Turn signal won't go off after turning, pls help
Need a little pointer here, everything works (i.e. the turn signal lights, the relay, both left and right, front and rear all works fine). The only thing is after making turns, the turn signal will stay on and I have to manually click it back into neutral. Any idea?
Thanks in advance.
Thanks in advance.
Mine did that. I had to replace the entire stalk unit that sits under the steering wheel. It has the turn signal, computer, cruise cont, and winshield wipe stalks. Under $200 from Sunset Porsche. Apparently there is a plastic piece that breaks and can't be fixed without replacement of the whole unit. Might be cheaper for you if you have less stalks
Yes there is a DYI with photos. I can't find it now. Sorry. Do a search. REMEMBER: you must disconnect to the battery before proceeding and don't reconnect battery or turn ignition on before you have reinstalled the airbag. You don't want the airbag to fire off. If I can find DYI, I'll give you the link or maybe someone else can help out with this.
