Oil capacity
Oil capacity
I have a repair manual for my 2002 C2 that has two entries for the oil capacity. It calls for 2.22 imperial gallons, but then indicates "change quantity" as 1.79. Where is the remaining oil? What should I expect when I drain the oil? Which do I use for refill (w/ new oil filter)?
Just did my 2001 C2 yesterday
I'm at 9.5 qts or more now. Still barely below full mark on dipstick. Has anyone else had to add so much?
I added the LN Engineering spin on filter adaptor too. Believe it or not, I first started with 8 qts and it barely hit the bottom of the dipstick. I drained it down overnight as I had to buy a 26mm deep socket to torque the new spin on the next day. I feel it dripped out quite a bit more than if I'd just let it drain for 20 minutes. So, if you have time, let it drain longer. I started with another 1/2 qt and it was barely over the minimum mark. Added yet another 1/2 quart and It was at about 1/2 way. That is when I started it and let it run for about 5 min, checked for leaks (none), and drove it for about 15 minutes. After a drain down of about 5 minutes, the level was still about 1/2 way (both electronically and on the dipstick). So, In went the last 1/2 quart. It still reads one bar below full on the electronic reader and a smidgen below full on the dipstick.
Again, I'm at 9.5 qts. now. Is this typical. I was expecting 8.5 to 9 at most. Any advice or knowledge on this? Chris
Eng w/ filter 9.3 qts
I just read this on Amsoil's site: 9.3 quarts with filter change.
Yours is a 3.6 L and mine is 3.4. Hmmm, that would make sense for yours to be at 9.5 qts, but not mine. Strange. Good luck.
Hey, we have a few guys that like to rally Brown's Canyon once a week or so if you want to join in. Nice way to get the rpms up and let it go. Pretty safe straight (both accident safe and johnny law safe too).
Have a great New Year and good luck. Let me know where you end up.
That's about right for the 3.4. 2.22 imperial gallons are 10.67 quarts for the 3.6 Liter. The 1.79 imperial gallons that is referred to in the manual are 8.60 quarts. I just don't know where the other 2 quarts goes? It can't be the filter.
Okay, finally took a peek at my manual. It says 9.3 qts or 8.75 litres for mine. That makes more sense! With my extended drain down time I bet I drained out at least another .2. It just kept dripping forever.
Hey, after you're done with your change and want to go on a drive, just let me know. I'm always looking for other enthusiasts.
I also go out to 4800 So. Redwood to buy and mix their race gas to get 94.5 octane. Car runs SO much better and smoother acceleration with it. It is Jensen's service if you have not tried it.
Have a good one / Happy New Year! Chris
I'll pm you then with my cell number. We have a fun little group of enthusiasts that likes to get out. Seems like we are all busy at different times which makes it hard. Did you get your oil all topped off and filled? Leaks? How much did it finally take?
So yes this is typical.
I buy 10 quarts for each oil and filter change. I put 9 in initially, then take the car out for a drive. I let it sit for a few minutes, then top it up to halfway between low and full.
You don't want to overfill it.
you guys must have a lot of patience....I let i drain 20 min or so and can only get in 8.5 at the most if i'm lucky. I know I should drain a little longer but having 3 month intervals, I don't care so much to wait till the last drop of oil
It seems like everyone is having a problem with drainage time. It is no surprize to me considering the flat design of the pan. There is no place for the oil to accumulate, so it's draining from a flat plate. My concern about this design is that unless this flat plate is exactlly parallel with flat ground, you may get a significant amount of oil pooling at the low end. The more of an angle the car is, the more oil that will not drain out. What concerns me most is if you drain the oil in the same unlevel stop everytime, although you are diluting your old oil at some rate, any metal or sludge may be settling and accumulating in that low spot.
Is there any guidance as to how oftern this pan should be dropped for a thorough cleaning?
I'm interested in the answer on how often to drop the pan too. I know LN Engineering makes a slightly deeper pan, but it is still flat too to my knowledge. Just to be OCD, on my oil change I put the old plug barely in, heated up a quart of Mobil syn that was 3/4 full and poured it through. I then undid the plug and it came out pretty darn quick and looked as clean as it went in. I did not expect to get sludge, but was at least hoping for washing some additional particles out....which may have happened...who knows. I left my car on jack stands and the angle was pretty forward. Looking back at it, I guess I should have lowered it and let it drip too. Does anyone do this?
