paint the lip or not..
Old 01-22-2012 | 05:57 PM
MkC2S's Avatar
I finally install the lip today after an incident with the railroad tracks....the body shop quoted me about $200-ish which is not bad..but I'm having 2nd thought about getting it paint..so should I leave it black or have it paint to match the bumper..What do you guys think?
here's a few pic of the new lip:
Old 01-22-2012 | 06:11 PM
Mother's Avatar
Mother is infamous around these parts
I would leave it ..... it's easier to touch up when it gets screwed up. I have a RUF front and ended up putting abs pieces underneath to keep it from chipping the paint when I hit things steep inclines, driveways etc.
Old 01-22-2012 | 08:09 PM
scarab440's Avatar
scarab440 is infamous around these parts
If the sides are painted I'd paint the lip. If they arn't then I'd leave it.
Old 01-22-2012 | 09:18 PM
aemr1968's Avatar
aemr1968 is infamous around these parts
Unpainted
Old 01-22-2012 | 11:21 PM
Peterpokerplane's Avatar
Peterpokerplane is infamous around these parts
I've got the same setup, and left mine black. I was just thinking the very first rub would cause the paint to flake, and it seems like it's a nightmare waiting to happen. However…if you do it and it works, then I would be tempted to follow suit.
Old 01-22-2012 | 11:48 PM
Gotnem108's Avatar
Gotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to allGotnem108 is a name known to all
Paint it
Old 01-23-2012 | 03:25 AM
FLY996's Avatar
FLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud ofFLY996 has much to be proud of
+1 (very first rub will cause the paint to flake)
Old 01-23-2012 | 07:48 AM
alpine003's Avatar
Leave it. You have a dark car so it would blend in better anyways than if you had a light color car. My $.02
Old 01-23-2012 | 09:26 AM
carbonissimo's Avatar
carbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud ofcarbonissimo has much to be proud of
I wouldn't paint it
Old 01-23-2012 | 09:57 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Unpainted. It is a wear item. You will end up replacing it every few years.
Old 01-23-2012 | 02:08 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
I have the same front bumper on mine along with Techart style side skirts. I left it unpainted because the front lip sits lower than the side skirts. This way the painted part of my front bumper matches the height with the side skirts to keep it more even looking from a side profile. The black lip does not stand out as much to make the car look front heavy (low) as it would if it were painted IMO.
Also, to the other postings it is a very low component that will be subject to road hazards and non-painted will probably hold up better visually.
Old 01-23-2012 | 05:38 PM
MkC2S's Avatar
thanks for the feedback guys....guess its unanimous..so I'll leave it unpainted..already scuffed up the bottom pulling out & in the driveway today.....and this is on a daily basis too....
yeah the black lip does kinda blends in with a dark color car..
Old 01-23-2012 | 06:27 PM
MerlinsGhost's Avatar
MerlinsGhost is infamous around these parts
I don't think painting it to match the car color is smart. But what I would do is spray it down with a black plastic spray paint. At least it would look finished and the paint is made to stick to plastic. If it gets scratched or dinged up you can spray it again. I had a lip on my till I tore it off getting into my driveway. Never put it on again, to much hassle trying to not scrap it on everything 3 inches or higher. But good luck either way.
Old 01-24-2012 | 12:39 AM
Tarek307's Avatar
Tarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond reputeTarek307 has a reputation beyond repute
Paint it and BE CAREFUL, looks much better painted!!!!
Old 01-24-2012 | 05:15 AM
mikegr's Avatar
mikegr is infamous around these parts
If you live at a place where streets are made of velvet, go for it, paint it.
Quick Reply: paint the lip or not..
