Brake Light question
I've noticed that when I apply pressure to the brakes my rear lights initially light up but when I continue to push down harder on the brakes they do not stay lit. Any guess on what the problem could be ? Maybe the brake light switch is going ?
I have an 03 C2 coupe. thanks.
I'm no mechanic but I would check the brake light switch first. Could be a loose/faulty wire in the switch that loses connection the further you depress the brake pedal. Or it could be shorting. Good luck.
@Snowball350 Its a pretty simple task as shown in the link. We offer two different brake switch models that would fit your 2003 C2. For more information about the brake switches we offer Click Here.
04-28-2022 12:38 AM
