1 Reverse light issue HELP!!!
Old 11-16-2012 | 04:20 AM
Black_911's Avatar
Black_911 has a spectacular aura aboutBlack_911 has a spectacular aura aboutBlack_911 has a spectacular aura about
So when I reverse only one reverse light comes on (driver side). I removed the light socket (while it's in "ON" position and reverse gear) so I can see the light on. I tried moving the bulb while in the socket and give it a flick, it suddenly lights up.
So then I put it back, drive the car then later on it stops working again...
It's frustrating how many people tells me my light is out!
I know it's not the "reverse light back up switch" because the other light bulb works. And I've replaced that last year when it went out on me.
Old 11-16-2012 | 06:44 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
If you wiggle it and it comes on there is a bad connection somewhere. First try replacing the bulb, it may not be making a tight connection. Be sure the socket is clean as well. If this is a no go, then it's in the wiring to the socket, so wiggle the wires to see which one makes it come on or go off and that's the bad one.
Old 11-16-2012 | 10:05 AM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
If you can wiggle the bulb and it lights up, my guess is you have a bad socket. I believe the socket has a spring underneath the contact point that makes contact with the bulb. The spring can loose its tension making for a loose fit.
Old 11-16-2012 | 03:04 PM
JSavinoJr's Avatar
JSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura aboutJSavinoJr has a spectacular aura about
As stated above it's probably a bad connection in the socket.
Old 11-16-2012 | 08:51 PM
copper's Avatar
copper has a spectacular aura aboutcopper has a spectacular aura about
+1
I had the same problem. I tried to pull the spring out to make contact that did not work. A friend had a wiring harness from an old car. We cut one of the sockets and used it for my problem. Works perfect now.
Old 11-17-2012 | 03:22 AM
Black_911's Avatar
Thanks guys for the input. I will try all the possibilities. I hope I don't have to replace the whole socket assembly. It cost about $150+ for the whole socket as one piece including the brake, turn signal.
COBB Tuning
01-29-2022 09:42 AM
nreddy
BMW //M
08-26-2015 11:42 AM
metzkaro
08-24-2015 02:59 PM
Walorus
08-18-2015 01:39 PM
Quick Reply: 1 Reverse light issue HELP!!!
