996 Clutch Repair Cost
Old 02-19-2013 | 06:12 PM
Romysc4s's Avatar
Romysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud ofRomysc4s has much to be proud of
I'm having my manual transmission rebuilt. While I'm at it I thought it'd be good idea to replace the clutch. I have 42k miles on the car, I bought it used 3 yrs ago with 37k miles and I assume it still has the original clutch. Can anyone tell me how much approximately it will cost to replace a clutch in the So Cali area?
Old 02-20-2013 | 06:14 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
I would think about $1000 or $1250 if you replace the flywheel. I would assume your doing this for preventitive reasons so there should be no damage to the cluch now, I would use a Spec Clutch and go with a stage 2.
Old 02-20-2013 | 10:13 AM
Romysc4s's Avatar
FLATT, thanks for the feedback. I took my car to Callas Rennsport in Torrance yesterday and I'm still awaiting for an estimate. Yes, I'm doing the clutch for preventative reason. I don't track my car and drive it on weekends only. Would it still be worth going with Spec Stage 2?
Old 02-20-2013 | 11:14 AM
FLA996TT's Avatar
I believe the class 2 (not 2+) clutch will last a little longer, basically it's designed for a bit more horsepower and since it's really not that much more $$ I would. Talk to your brake guy and see what his opinion is.
Old 02-20-2013 | 12:07 PM
pmkazz's Avatar
pmkazz is infamous around these partspmkazz is infamous around these parts
Since they are removing the transmission, 95% of the hard work is already done. OEM clutch set is about $450. OEM Flywheel, which you should not need with 42K miles (unless abused) is around $800.
Romysc4s's Avatar
Makes sense. My concern is if it's going to make the clutch much stiffer if I go to the Spec Stage 2.
Old 02-20-2013 | 12:09 PM
white out's Avatar
white out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to beholdwhite out is a splendid one to behold
FYI the Spec stageII clutch in my STi didn't hold as much power (or last as long) as an Exedy OE replacement clutch. I don't know how the rest of their clutches are, but that turned me off.
Old 02-20-2013 | 12:41 PM
FLA996TT's Avatar
You could also look at sachs clutches. Exedy does make a nice OEM Spec clutch. Choosing one and or what class is largely dependent on how you drive and what mods you may do to the engine in the future, increase HP and torque you will need a higher stage, if you plan on doing nothing go OEM. Lead foot/sport street stage 2 IMO, normal OEM. Track/DE go stage 2+ or three.
Old 02-20-2013 | 07:45 PM
Romysc4s's Avatar
FLA996TT, as always thanks for your support. Your wealth of knowledge is valuable to the Porsche community.
Old 02-22-2013 | 09:04 AM
pjweb911's Avatar
pjweb911 is infamous around these parts
Quotes for clutch repair, IMS and flywheel.
Here is what I found when I went out to research the cost of replacing my clutch in the East Bay of Northern California:
Indy 1
Clutch
Parts $834
Labor $1160
IMS
Parts 700
Labor $435
Flywheel
Parts $1000
Total together: $4129
Indy 2
Clutch
Parts $780
Labor $1226
IMS
Parts $619
Labor $453
Flywheel
Parts $975
Total: $4054
Old 02-22-2013 | 09:17 AM
FLA996TT's Avatar
You may not need the flywheel since you're not experiencing any problems and you're doing it on a preventative nature. Also, the labor should be lower because you're already there with the other work your having done. This is something you should be able to negotiate.
FYI Exedy Clutch kit $571.11 on Amazon. I priced an 02-03 911 C2
Exedy site; http://www.exedyusa.com/ You can use this site for part numbers and fitment.
Oh, while you're there I'd have them do the RMS.
This is what I did when I bought mine, new LNE IMS bearing, new RMS, complete fluid change (oil, brakes,coolant), high flow air filter, and new battery.
Indy 1
Clutch
Parts $834
Labor $1160
IMS
Parts 700
Labor $435
Flywheel
Parts $1000
Indy 2
Clutch
Parts $780
Labor $1226
IMS
Parts $619
Labor $453
Flywheel
Parts $975
Total: $4054
Old 02-22-2013 | 04:09 PM
Romysc4s's Avatar
Thanks pjweb. I'll do the IMS for sure. Keeping my fingers crossed that my clutch is still good.
Old 02-23-2013 | 04:17 PM
FLA996TT's Avatar
Make sure you get the INS Solution! Call Jake and find out who can install this, because no when can unless they have been trained by Flat 6 or LNT,it' not a direct replacement.! This is the perfect solution, period, or contact LNE
Old 02-23-2013 | 07:23 PM
Romysc4s's Avatar
FLA996TT, I'm taking it to Callas Rennsport in So Cal. Tony Callas is very well known in the Porsche community. He works on race cars, and trains Porsche mechanics. I think I'm in good hands.
http://www.callasrennsport.com/
Old 02-24-2013 | 07:02 AM
FLA996TT's Avatar
Oh, I'm sure you're in excellent hands, all I was trying to say was don't go through the exercise of replacing the bearing with a bearing, get the IMS Solution, no moving parts problem solved. It's only been on the market since January and was developed between LNE and Flat 6 Innovations, I wish it hed been available when I die mine, I used the LNE IMS retrofit ceramic bearing.
Here is the link ; http://www.flat6innovations.com/
This is why I mentioned for him to call Flat 6 or LNE.
Quick Reply: 996 Clutch Repair Cost
