Door not closing when window all the way up
My driver and passenger doors are not closing when windows are all the way up. It seems that the windows are interfering and not allowing the doors to close. I noticed that when I open the door handle I hear the regulator but window does not go down. If I manually push it down while holding handle then letting go with handle window goes up. I tried to reset the windows but that did not fix it. I read that it could be the micro switch inside the door lock mechanism but I am suprised that both doors have the same symbtomes.
Usually it's a bad regulator if you can push the window down. The cables stretch out over time and even though the motor works, the window won't drop. In your case though. It sounds like there's more to it. Micro-switches may be involved as you suspect. It is odd that both windows have the same issue.
What happens if you push the window down without holding the door handle? Does it still go right back up?
When my regulator failed, I could easily push the glass down without holding the door handle. When I closed the door, it would move back up to the proper position.
I think your problem is micro-switches or something else. Hopefully a reset will fix it.
I know the sound of the glass of glass is like nails on a chalkboard! Definitely sounds like a window regulator. They do go, and thankfully not expensive, ie <$100. If you have a workshop it can be a DIY. Instructions on Pelican and elsewhere for a Boxster (same internals):
http://www.pelicanparts.com/techarti..._Regulator.htm
It looks like that on the Right side the regulator is bad since it started to make noise now. On the left side I was able to adjust the height from the two torx screws on the bottom of the door and that seems to work for now.
Can anyone recommend a place to buy the regulator. Thanks
faandba - We offer a few different options for window regulators. For more information Click Here.
