Dectane LED Reverse Light
I've got the dectane LED tail lights on my 2000 cab. I've had them for about 9 or 10 months and they've worked beautifully. Yesterday, I realized that the white reverse light doesn't come on on the drivers side. I'm not very well versed in electrical issues, so I thought I would ask for some advice from any of you as to what the problem might be. Thanks in advance
led bulb check out
Remove the led bulb, using 12 volt power source (I use a small battery charger for motorcycles) put the + /red cable end to the center connection and the - black end to the side connection. with power on it should light up, if good
There are no bulbs in these lights.
Feel kind of stupid. Should've looked at the lights before even posting. Turns out the Reverse light is a standard automotive bulb, not an LED. $4 later, both reverse lights are working.
away
09-04-2015 12:30 PM
