Please help. Horn going off when I turn?
Old 08-09-2013 | 08:27 AM
BOOSTTT's Avatar
BOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to beholdBOOSTTT is a splendid one to behold
Unhappy Please help. Horn going off when I turn?
My 99 C2 is honking when I make a sharp turn, or bumpy turn. If I hold the horn/steering wheel cover out, it stops, but it's embarrassing. What is the fix?
I also need to pull my spark plug tubes. What is best to use...Marine plug of some type?
Thanks for any help.
Old 08-09-2013 | 08:42 AM
MR2FAST's Avatar
MR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to behold
LOL!!!! I'm sorry I don't have a fix (except maybe removing and replacing the horn cover maybe?) but I imagine this being very hil arious and frustrating at the same time. GL!
Old 08-09-2013 | 09:02 AM
Dennis C's Avatar
As I recall, there are some little rubber bumpers on the steering wheel frame that deteriorate over time. This allows metal-to-metal contact when you turn or brake hard, which causes the horn to honk. You should be able to find a DIY fix online on rennlist or renntech. Remember to disconnect the battery before you unplug the airbag and make sure to reconnect the airbag before you reconnect the battery! Otherwise you'll get a CEL.
Old 08-09-2013 | 12:17 PM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
Dennis C has the right idea. There is a metal horn plate under the airbag cover which has 4 rubber bumpers. Replacement price for a new plate is around $50 if that's the problem. Hope you get it fixed.
Old 08-09-2013 | 01:42 PM
jayi836's Avatar
jayi836 is infamous around these partsjayi836 is infamous around these parts
On the spark plug tubes I used an 1-1/4" and shaved it a bit the 1" model was too small. I also used a chip puller I had in the tool box on angle the teeth were no long enough to scratch anything. All inexpensive parts I replace the tube and the seals.
Old 08-09-2013 | 08:57 PM
BOOSTTT's Avatar
The horn is definitely from the weight of the air bag compressing the rubber underneath. I also noticed, it only does this when it is really hot. it was honking like crazy tonight 103 degrees, but this morning at 70 degrees, it did not honk at all. I just stuffed some thick paper around the air bag cover before i drove home from work. It did not honk after that. Does anyone know the part number for the rubber spacer?
Also, thanks for the diameter for the marine plug. I'm not sure what a chip puller is though. What does that do? Sorry, but I just want to be sure and do it right. I have oil drips on my headers right after doing spark plug changes. I'm pretty sure it's the plug tubes on passenger rear side only. Looks like some seepage around that area under the headers too? Not sure what is causing the gunk in that area.
Old 08-10-2013 | 04:42 PM
jayi836's Avatar
Chip puller was used back in the day when you could remove and swap chips on a circuit board.
I had my car apart and the 1" plug didn't fit so I opened up the chip puller and inserted it all the way hooked the tube and popped it out.
My Cam seals were leaking also so I ended up pulling the rear bumper and the mufflers out to see what I was doing.
Also had an engine covered in gunk perfect time to clean it.
https://lh4.googleusercontent.com/-3...126_134844.jpg
Stainless Steel with Insulated Vinyl Grip IC Puller - ET-10 - Amazon.com Stainless Steel with Insulated Vinyl Grip IC Puller - ET-10 - Amazon.com
Old 08-10-2013 | 05:19 PM
BOOSTTT's Avatar
Looks great! I want mine to look clean like that! Thanks for the chip puller link. Awesome!
Old 08-11-2013 | 12:17 AM
jayi836's Avatar
Old 08-12-2013 | 01:42 PM
Pors-Vette's Avatar
[QUOTE=BOOSTTT;3913440]The horn is definitely from the weight of the air bag compressing the rubber underneath. I also noticed, it only does this when it is really hot. it was honking like crazy tonight 103 degrees, but this morning at 70 degrees, it did not honk at all. I just stuffed some thick paper around the air bag cover before i drove home from work. It did not honk after that. Does anyone know the part number for the rubber spacer?
QUOTE]
Here you go. Looks like prices have gone up a bit since I last replaced mine.
http://www.partstrain.com/store/deta...3-1646393.html
Old 08-12-2013 | 08:04 PM
BOOSTTT's Avatar
Thanks, pors. Funny how well paper has been working. : ). Hey Jay, that's just what my engine looks like in that last rear pic. I hope to get the chip puller and do the job this wk end.
Bmw M3 Guy
02-21-2018 10:29 AM
kensilver
09-17-2015 05:03 PM
troyztoyz609
09-17-2015 07:09 AM
dailydriver
09-13-2015 10:01 AM
su_maverick
09-08-2015 12:12 PM
