OT: Behr Garage floor paint....
Originally posted by PorschePRH [/i]
[B]For home use, you just can't beat the snap together tiles that float on the floor like Racedeck, or what I have, Motormat...
The paint job looks good, the tiles mats I like. Where can i get these mats?[
I got mine at www.MotorMat.com 3 years ago. The picture is very recent, so that's how old they are in the pic.
The other very popular one is www.racedeck.com.
I suggest asking for samples of the different styles and colors before making a big order.
I do a lot of work on my cars and other hobbies on this grarage floor and one thing I would not like is a raised texture on the tiles. Motormat has air/water holes, but nothing raised. Rackedeck has different models and most have some sort of raised pattern, which would make it difficult to roll things like creepy crawlers, chairs on wheels, etc. Also the texture would hurt while you are on your back or on a knee.
If you plan to jack up your car, you need to have some sort of thin boards that you can put down to protect the floor from being crushed by the huge pounds per square inch of a jack. I use 1/8" fiberboard cut into 1x3' pieces.
It doesn't take a very thick or strong board to spread out the load, but if you don't put something you will permanently dent the tile -- just like you can chip off thick paint coatings with too much concentrated force. Otherwise it is very hard to damage the tiles. You can put any chemicals you want on there and they stay undamaged.
And if you damage a tile, it's a 10 min process to replace it. Order a few extra.
One last thing: Color choice is hard, but what I found is that grey and yellow are the easiest colors to keep looking good. But all yellow or all gray doesn't look great, so I mixed them. At the time it matched the yellow Viper that I had, but it's ok with just about any car color. If you go with Black and White, or dark colors like Blue, expect a lot more cleaning to keep it looking good.
[QUOTE]Originally posted by s.bjorn.hoffman
[B]
If you go to www.racedeck.com, you will see garages that make mine look like a run down utility shed....
[B]
QUOTE]
PorschePRH,
I love the look of your garage - ultra professional!
Now I´ll be looking for a similar solution for my garage, which is on the list for a make over.
QUOTE]
PorschePRH,
When I moved into my home the previous owner had used the Behr garage floor coating. The paint started to lift from the hot tires in less than a year later. I can't be sure if he prepped the floor properly before using the coating though. It also looks like he only used one coating.
I have finished the second coat and had two days to dry. It looks fantastic, solid finish, no bare spots or thin areas. My only concern is as been mentioned, using floor jacks ect on it. Time will tell of course.... either way, its down, and i get to live with it!
Tile is also an option if your up to it i think it looks the best. I have it in my garage and it is great, easy to clean and just as durable as anything else. Although i must asmit that race deck does look good.
Rather than floor paint, I think the 2-part epoxy coatings work much better as they actually bond to the concrete surface like any other epoxy. Paint is paint and doesn't actually have the bonding action that epoxy does.
Originally posted by sharkster
You are all bling now aint ya?!! Hey so what's been going on... drop in next week when we get back from the GAF and you'll have to go for a ride
Be there next week for sure!
there are very large thick rubber mats made of recycled tires....they are less expensive than the snap together tiles and definitely worth it...no matter what the paint will not last more than a couple of years and looks disastrous as it starts chipping.....good luck!
Originally posted by mooty
i did my sister's garage for her. race deck floors. yes, painting the walls and ceiling was painful. i think i permanently damaged my rotator cuff....
race deck is easy but has one problem, if your garage get REALLY hot, the floor will bulge up a bit. once night comes along and temp cools down, floor flattens again. it does that every day in the garage.
NC 996TT
03-23-2023 06:19 AM
