Car steering wheel shakes over 70mph
Old 04-11-2014 | 10:33 AM
Sameerl99's Avatar
Sameerl99 is infamous around these parts
I replaced my rims recently because they were bent and caused my car to shake on the road. I have a 2004 996 C2 and my steering wheel shakes when i go past 70mph on the highway. What would be the common symptoms or quick fixes...alignment, balance tires...any suggestions.
Old 04-11-2014 | 10:42 AM
Pors-Vette's Avatar
Pors-Vette is a jewel in the roughPors-Vette is a jewel in the roughPors-Vette is a jewel in the rough
Start with balancing your tires. Inexpensive.
Old 04-11-2014 | 11:15 AM
FLA996TT's Avatar
FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !FLA996TT Is a GOD !
Agreed, start with a balance. Are you sure the rime you purchased are true? Did you keep the same size or move up? I wouldn't think it's an alignment problem as that would make the car pull to one side or the other. Also, make sure the tires are on the correct side if unidirectional, they could be reversed. They should have been put back in the same location they were removed from.
Old 04-11-2014 | 11:34 AM
bal's Avatar
bal
bal is infamous around these parts
I would actually start by checking that the wheels are true. My rears were not (left more so than right) and it was very visible when put on a lift and spun. Next step would be balancing.
Old 04-11-2014 | 11:48 AM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
go to tirerack.com and search installers that have hunter road force equipment. Have all 4 checked out..sometimes a regular balance is not good enough. I've noticed the 996's are very sensitive with wheel/tire balancing. or ask a local guy with a good set of wheel/tires to try
then move on to other possibilities
Old 04-11-2014 | 11:49 AM
geetee's Avatar
Talking
Why are you driving faster than 70 anyways? jk
Old 04-11-2014 | 12:45 PM
Sameerl99's Avatar
Thanks guys appreciate it. I bought new set of rims and tires and I upgraded it from 18s to 19s. I will start with getting a balance and see if it affects the current issue. I just want to have everything good to go since the weather has finally turned around and get the most performance from my new summer tires.
Old 04-11-2014 | 01:44 PM
Cannonball996's Avatar
Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !Cannonball996 Is a GOD !
if you were driving on a bent rim, then you may have torn up a tie rod bushing
Old 04-11-2014 | 11:40 PM
Elephant Chuck's Avatar
Elephant Chuck is infamous around these parts
Do I understand correctly that the car shook with the old wheels, and now shakes with the new wheels too?
Old 04-13-2014 | 09:21 PM
juanchi300's Avatar
juanchi300 is infamous around these parts
Check for fix flat liquid inside tires. Or check your rack & pinon terminals
Old 04-13-2014 | 09:32 PM
Saibot's Avatar
Saibot is infamous around these parts
Did you end up getting them fixed? how much did it cost if you dont mind me asking.
Old 04-14-2014 | 08:42 AM
bal's Avatar
bal
As I recall one wheel was about $280 but that included fixing curb rash. Of that, the straightening was $150 or so. The "wheel guy" (my alignment shop subs it out) uses some kind of hydraulic method the straighten the wheel. The result is that it is like new both in terms of being true and the finish.
COBB Tuning
01-29-2022 09:42 AM
no1joey
09-02-2015 12:32 AM
ppwchiang
08-20-2015 10:28 AM
pwdrhound
08-20-2015 05:54 AM
MAcarbon
08-19-2015 04:52 PM
Quick Reply: Car steering wheel shakes over 70mph
