997 parts that fit the 996
Old 10-27-2015 | 09:07 PM
dan_189's Avatar
dan_189 is infamous around these parts
Hi all,
In the quest for better condition parts I have found that there are quite a few parts from a 997 that will fit a 996. The obvious advantage is the 997 being newer so some of these parts can be in better condition than older 996 parts...
Wanted to start a list of the parts from a 997 that fit a 996 without any modification
So far I have:
- Headliner (coupe)
- Overhead interior light (coupe)
- Seat belts (coupe)
- Air box including air filter
- Front strut dust caps
- Shifter mechanism including SSK kit
- Seat belt interior caps (coupe)
Feel free to add to the list
I did do a search and couldn't find any threads like this so thought id start one!
Cheers
Old 10-27-2015 | 09:44 PM
B8_RDC's Avatar
B8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond reputeB8_RDC has a reputation beyond repute
Oil filter but I guess that is the other way around hah.
Old 10-28-2015 | 08:48 AM
alpine003's Avatar
Actually you'll find quite a few things that will fit as the 997 still uses many parts with the "996.xxx.xxx..." designation just like the 996 where you can find some parts on it with the 993 designation. However, there are more similarities between the 996 to 997 so the better question should really be what "doesn't" fit between those two IMO.
Old 11-06-2015 | 09:21 PM
kpl's Avatar
kpl
kpl is infamous around these parts
anyone know if the visors swap over? I'd like to get some that could slide back. I sit so far back that the stock ones are useless most of the time.
Old 11-09-2015 | 08:35 AM
914rrr's Avatar
914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of914rrr has much to be proud of
Roll bar, especially a Porsche Tequipment one? I've seen some aftermarket roll bars that stated their roll bar would fit both a 996 and 997.
Old 11-10-2015 | 08:16 PM
dinicor's Avatar
dinicor is infamous around these parts
Mufflers? I'm asking.
Old 11-18-2015 | 07:58 PM
MkC2S's Avatar
dealer installed a 996 coolant reservoir tank in my 997. so I guess it could be vice versa
Old 11-18-2015 | 08:20 PM
dan_189's Avatar
I actually dug a little deeper, does anyone know if the front plastic section of a 997 headliner will fit a 996? The part number changed from a 996 to 997 while the actual material and rear plastic remained the same 996 part number.
Thanks!
Old 11-21-2015 | 11:45 AM
Porsche_Shiftin04's Avatar
Porsche_Shiftin04 is infamous around these partsPorsche_Shiftin04 is infamous around these parts
I wonder if the dash would fit. The door panels might as well. The door line is different but I don't think that makes a difference. The door line is the outer skin.
Old 11-22-2015 | 10:52 AM
996inTX's Avatar
996inTX is infamous around these parts
I'm pretty sure the blinker fluid is interchangeable .
Old 11-26-2015 | 10:18 PM
IslaTurbine's Avatar
IslaTurbine is infamous around these parts
Alternator.
911TurboRules
11-17-2015 12:51 PM
joevettesj
10-13-2015 01:26 PM
gsieck
10-12-2015 12:49 AM
fjc32
10-07-2015 07:41 PM
