996 Lowered 1" Wheel Offset Question
Old 11-27-2015 | 10:50 AM
NYoutftr's Avatar
NYoutftr is a splendid one to beholdNYoutftr is a splendid one to beholdNYoutftr is a splendid one to beholdNYoutftr is a splendid one to beholdNYoutftr is a splendid one to beholdNYoutftr is a splendid one to beholdNYoutftr is a splendid one to behold
Will the following offsets work on a 2003 Narrow Body 996 C2, that will be lowered 1"?
The wheels were made by cargraphic for 993 narrow body.
#5130901847 = Cargraphic Wheel for Porsche PCD 5x130 / 9,0x18ET47
#5130111862 = Cargraphic Wheel for Porsche PCD 5x130 / 11,0x18ET62
Thanks for any help you can give.
Old 11-27-2015 | 02:37 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
That should fit fine....225/40/18 front should be fine but it'll be a little stretched on a 9 wide.
235/40/18 can possibly rub a little depending on camber. If it does rub you can use a small spacer. I used a 43mm off set on a 9 in the front without issues.
Old 11-27-2015 | 03:06 PM
NYoutftr's Avatar
I was a little worried about the stretch to a nine inch rim also.
I am cautious about getting wheels, as I still have upper strut mounts and drop links to get, before the new sway bars, coil springs and bilsten B8s go on.
I might be putting the cart before the horse, just didn't want to pass on the wheels.
Thanks for the information.
Cummins990
01-03-2017 08:10 AM
918spyder
11-27-2015 07:40 PM
hoeferland
11-10-2015 05:42 PM
pumptech
11-08-2015 01:22 PM
Relegate
11-07-2015 09:33 AM
Quick Reply: 996 Lowered 1" Wheel Offset Question
