Max rear tire size
Old 03-17-2006 | 02:48 PM
JSmith5690's Avatar
JSmith5690 is infamous around these parts
Max rear tire size
My 996 is due for some new rear tires. It currently has 285/30/18's on newer (02+) carrera 5 spoke wheels. What is the widest tire size that can safely fit on my current wheels. Thanks in advance for any responses.
Old 03-17-2006 | 04:05 PM
Kevin D's Avatar
P1 911
Kevin D is a glorious beacon of lightKevin D is a glorious beacon of lightKevin D is a glorious beacon of lightKevin D is a glorious beacon of lightKevin D is a glorious beacon of lightKevin D is a glorious beacon of light
...11inch rear's (width) with 315's is the widest you can go with the proper offset of course. Why do you want to go so wide in the first place? I have 285 on my 10inch rears on my 02' C2 coupe and have NO traction issues....supercharger upgrade maybe? Or just for the look?
--- Kevin
*** Sorry...just re-read your post/question, you can technically go wider on your current 10 inch wide rear rims but you'd lose handling....just stay with the 285 size unless you change to wider rims
Old 03-17-2006 | 04:51 PM
20C4S's Avatar
295 will fit ur wheel but they look kinda funky imo. stay with 285 is what i'd do.
Old 03-17-2006 | 09:22 PM
JSmith5690's Avatar
Thanks for the input.
Old 03-17-2006 | 09:50 PM
jungzilla's Avatar
jungzilla is infamous around these parts
I went with 295's no problem. they're on 19" champions though
Old 03-18-2006 | 06:01 PM
996Jammy's Avatar
996Jammy is infamous around these parts
i went with mich 295/30/19 on a 10.5 rear and it rubbed and stuck out.
iforged says go down to a 275/30/19 and it should be fine. we'll see...
Old 03-18-2006 | 06:02 PM
996Jammy's Avatar
FYI...just in case you guys say offset issue...
was also told their et+56 offset is correct for narrowbody.
The_Ruski_Driver
10-25-2015 09:40 PM
AJUSA.com
997 Vendor Classifieds
10-08-2015 06:50 PM
ModBargains
Audi Vendor Classifieds
09-01-2015 06:26 PM
ModBargains
08-20-2015 01:28 PM
08-19-2015 07:35 PM
