Passenger Front turn signal not working
Old 04-20-2023 | 06:42 AM
nonames123's Avatar
nonames123 is infamous around these parts
New here so hello all,
I have done lots of searching but can't figure this out. Here is the issue
Front passenger turn signal does not work, it was flashing fast and was very dim.....now it doesn't light at all but rear is still flashing fast
There was some corrosion on the bulb holder socket, tried cleaning up and bending the tabs but did not work, so I purchased a new one --- also did not work.
Put all new bulbs in front TS, rear TS and side markers----- Nothing, same issue with passenger TS not lighting at all and rear flashing fast
Replaced the flasher relay ---- did not help
Checked for any bent or corroded pins in the main harness - all good there
Any and all thoughts are appreciated!!
ALE-SUPERBIKE
01-07-2023 11:35 AM
Scott in Cincy
08-23-2021 12:59 PM
slverblk996tt
02-07-2020 03:31 PM
Brainfry
12-30-2019 09:31 PM
Torque-less
04-04-2019 06:26 PM
