Dead Battery and Locked Hood
Old 02-09-2004 | 03:53 PM
akprasad's Avatar
akprasad is infamous around these parts
As the owner of a 99 Cab, in the Northeast I haven't driven my car in the last few months and now I am stuck with dead battery and locked hood.
Any ideas on how I can get the hood open without having to have the dealer flatbed the car?
Thanks.
Old 02-09-2004 | 04:01 PM
retsel75's Avatar
retsel75 is infamous around these parts
996 dead battery
In your operator's manual there is a description of how to do it. Basically you open the driver's door with the key. There is a fuse box located on the left wheel housing under the instrument panel. Open it up and there is a "red" terminal that you jump with the positive lead and you can ground the negative to any body part. That's the trick!
Old 02-09-2004 | 04:40 PM
Rodis's Avatar
Rodis is infamous around these parts
it happened to me several times (had an aftermarket stereo drawing on the battery) I bought a charger that you plug into the lighter and charged the battery enough to work the door locks and trunk release. But dont try to start the car with the charger plugged into the lighter because it will burn the fuse on the charger. At least mine did. Once the trunk is open, you know what to do. But when storing the car for a long time or going on vacation, I leave the trunk adjar.
Ron
Old 02-09-2004 | 06:24 PM
akprasad's Avatar
Red Terminal added in 2000
I appreciate the quick replies but in the 1999 996 there is no red terminal - I checked the box.
Also I tried using the Coleman Powermate through the cigarette lighter but still not getting enough juice to get the hood to operate.
Any other ideas?
Old 02-09-2004 | 07:29 PM
ScottW's Avatar
ScottW is infamous around these parts
I think there is a quick release behind the passenger side headlight. Try this thread on
http://forums.rennlist.com/rennforum...ght=trunk+help
-Scott
Old 02-09-2004 | 07:55 PM
Rodis's Avatar
when you used the power mate did you get any juice at all or is it completely dead? I know the dealer sells a similar mechanism that maintains the battery. Maybe try that (about $75.00) because whether or not it helps this time its always good to have one and keep plugged in on long/extended rests.
Ron
Old 02-09-2004 | 08:41 PM
Tool Pants's Avatar
Tool Pants is infamous around these parts
There are several ways to get into the hood. http://forum.boxa.net/index.php?showtopic=3761&hl=cable
Including some not in the link.
Old 02-12-2004 | 07:52 AM
akprasad's Avatar
I appreciate all the replies. After some deliberation, I ended up creating a device consisting of two Male Cigarette Lighters connected to each other. (Radio Shack part #270-1590)
Plugged one end into a running car and the other into the dead Porsche - and waited a few minutes and was able to get enough juice to open the hood.
I learnt my lesson the hard way, but I wanted to share my lesson so someone else doesn't need to go through all the trouble.
pwdrhound
09-13-2016 10:44 AM
Axxlrod
10-26-2015 11:54 AM
Twinturbofan
09-11-2015 04:14 PM
lokmeup
09-09-2015 09:24 PM
JSF721
Detailing
09-08-2015 07:57 AM
Quick Reply: Dead Battery and Locked Hood
