Battery dead, can I open the trunk ???
I have what seems to be a flat battery on my 996 C2. I've connected a booster to the the door pin and the + terminal in the footwell and sure enough the alarm goes off but the method in the handbook to switch it off doesn't work (turn door lock on and off) and I still can't pop the hood to get to the battery.
Any advice greatly appreciated.
Well woo-hoo! I went out and bought a $10 set of jump leads hooked it up to my Vespa's battery and used the metal jacking point underneath the car for the negative connection (so I could keep the doors closed). The alarm went off and the key in the door (lock unlock) method still wouldn't switch the alarm off but the key fob just about found enough power to shut off the alarm. Popped the boot and gave the battery some juice and all is good the world.
gadgetman
09-10-2015 03:29 PM
