Removing Ignition Lock Assy
What a pain I'm trying to remove the ignition keylock and switch assy. I removed the (1) nut and bolt that attaches it to the steering column and it seems loose and pulls out about 1/8" but will not come out all the way, seems almost like you need to push a pin or something to release it.
Any gurus out there.
Nice thread but,
Originally Posted by Redridge
Pin
Originally Posted by porschespeeddem
Got that one on the head. On the top of where it slides in, there is a pin to depress. Can be tricky on some, getting the pin depressed and wiggling it out at the same time, some are stuck in pretty good.
When I have done them, I have the key already in the on position, and the ignition barrel already out, unplug the harness at the back to keep the battery from running down. And the new one will install in the "on" position. So, to answer the original question, press it in with the key on, it shouldnt take a lot of effort.
Problem
BFH. Seriously though, I assume you went through the several layers of threads on this issue on renntech? There seemed to be quite a bit of discussion in the boxster area. Have you tried pulling the instrument pod off to get a better view? Its fairly easy to do if you haven't done so already.
Yes
Yes pod off
http://www.webbspot.com/porsche/picture.jpg
thanks Daytrader
Originally Posted by daytrader
Register at PhotoBucket. Upload the pics then copy and paste link to 6speed's thread.
