Video: Carrera C4S Drifting/Power Sliding
Old 03-13-2007 | 10:54 PM
328DTM's Avatar
328DTM is infamous around these parts
Here's a video I shot of a friend playing around track side.
Enjoy:
http://www.youtube.com/watch?v=7h4DEjB4oPQ
Old 03-14-2007 | 12:22 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
can my 4s do that too?
oh man, did your friend burn thru a set of tires?
Old 03-14-2007 | 12:23 AM
Chasen1211's Avatar
Chasen1211 is a jewel in the roughChasen1211 is a jewel in the roughChasen1211 is a jewel in the rough
wow! definetly didn't expect a C4S to be able to do that! how much power is transfered to the front wheels of a C4/C4S/Turbo???
Old 03-14-2007 | 12:25 AM
angldrkns9's Avatar
maybe the rears were shot from the track already.. i think if i had bad traction in the rear, i may be able to do that
Old 03-14-2007 | 12:34 AM
porschenut911's Avatar
porschenut911 is infamous around these parts
That's sweet, love those wheels too!
Old 03-14-2007 | 12:50 AM
John Romano's Avatar
John Romano is infamous around these parts
I thought that a C4S had 4 wheel drive?
Old 03-14-2007 | 01:41 AM
AsianImage's Avatar
AsianImage is a jewel in the roughAsianImage is a jewel in the roughAsianImage is a jewel in the rough
yeah maybe the "experts" can explain that...if it is indeed a 4 wheel drive there is no way it can slide like that right? Maybe I need another lesson in basic physics. But if power is going to all 4 wheels...the car shouldnt be "sliding" anywhere right?
either way...cool vid. I would love to get some video of my doing some burnouts and slip sliding around.
Old 03-14-2007 | 01:54 AM
dhrecon's Avatar
dhrecon is infamous around these parts
Wowwaa weewhhaa!! His PSM definitely was off and the clutch had to be crispy after he was done. I tried that once in a parking lot and one whiff of the clutch ended my wannabe drift. Got skeerd.
Old 03-14-2007 | 02:43 AM
newport996's Avatar
newport996 is infamous around these partsnewport996 is infamous around these parts
the front is normally getting only 5% power....when the wheels spin, then it gets up to 40% MAX....turn the PSM off and you can slide it around....he probably will need a clutch and some tires if he does that too much, but its doable in a C4/C4S/TT...
Old 03-14-2007 | 04:17 AM
Redridge's Avatar
its the only 4 wheel drive system that can drift... it was designed to drive like the c2. (Unlike the 997) I think its electronically actuating the 4 wheel linkage while the 993/996 is a viscouse mechanical coupling (so it needs slippage in order to work and link the rear/fronts together). Also what is happening there is that the front brakes has a monster bite on the front discs and rears are only @20% of the cars stopping power... so the only way it release the energy is the weakest grip and thats the rear wheel.
PSM will be activated as soon as you step on the brake (which he is doing) so its actually trying to brake the car (PSM lights are probably going nuts ) but it cant since the wheels momentum is driven by the throttle and overcomes the rear brakes. So he actually has his foot on the brakes and gas at the same time (takes practice), if you give it enough gas it will break free from the brakes and the inertia of the wheel will overpower the brakes. Wipping the car around also helps break traction. PSM probably doesnt detect high speed so it probably doesnt think the car is in trouble (another scenario), so it lets him has his fun.
He is also "Efin" up his tranny, clutch, tires, brakes, 4 wheel couplings and other things Im sure...but...I guess it fun.
The c4 system is pretty impressive, Walter Rhoule (sp) prefers the c4 over the c2... more and more people (professional, car experts) are starting to realize the c4 might be the better choice.. this technology did come from 959, that should speak for itself.
Old 03-14-2007 | 10:13 AM
angldrkns9's Avatar
so my 4S can do that!
Old 03-14-2007 | 11:40 AM
WARDHOG's Avatar
WARDHOG is infamous around these parts
I can't do that because my gas is E-gas meaning as soon as you hit the brake pedal, the throttle is lifted off electronically. My car is a MY03.
Old 03-14-2007 | 11:52 AM
Redridge's Avatar
just watched the video again, your right... at some spots of the video, it actually looked like he was standing still (braking) while rears are spinning, but the car was still actually coming around... then it is just throttle alone and no brakes...
Old 03-14-2007 | 01:05 PM
AsianImage's Avatar
great info....very cool
Old 03-14-2007 | 01:11 PM
iLLM3's Avatar
You can def tell its still AWD, the way his rear flips around he isnt sitting in that one spot just roasting the tires and can actually still accelerate into a figure 8 or another little drift, very possible!
With some stiff sway bars its even easier to get oversteer and control it
Quick Reply: Video: Carrera C4S Drifting/Power Sliding
