Are coolant leaks somewhat normal?
Old 05-08-2007 | 01:44 PM
ElusiveC4's Avatar
ElusiveC4 is infamous around these parts
Have most people on here replaced the coolant resevoir tanks on their 99s? im debating having this done even though right now just replacing the cap seems to have done the trick.
Old 05-08-2007 | 10:10 PM
eight0zero's Avatar
eight0zero is infamous around these parts
mine leaked... it was replaced right away - the dealer told me that this is a pretty common problem
Old 05-09-2007 | 12:03 PM
CLS's Avatar
CLS
CLS is infamous around these partsCLS is infamous around these parts
Originally Posted by YoopsRacing
on a 23k mile 1999 - looks like a few drops leaking around rubber pipe, on to my garage floor without any pressure fitting that I can see -
Looks like the fix is just to add a hose clamp of some sort.....is this normal?
I think your going to need a coolant tank mine presented itself similar to yours. I have a 2001 C4 3.4L but I think they are using the same plastic coolant tanks that crack due to the heat in that area, just MHO.
Old 10-22-2010 | 09:10 AM
Tmainevent's Avatar
Tmainevent is infamous around these parts
Haha this thread makes me belly laugh!! I have the same problem---getting my cap replaced asap!! Thanks guys!!
Old 10-23-2010 | 05:21 PM
rrrruben's Avatar
rrrruben is infamous around these parts
I experienced a minimal loss of coolant over the last month. When I refilled the coolant, I noticed a small amount of coolant around the lip where the reservoir cap is attached. It appears the reservoir cap is the original; part# 996-106-447-01. I ordered an updated model from Pelican Parts; part#996-106-447-04; $23.00. Hopefully, this will resolve this issue.
Old 10-24-2010 | 01:02 AM
MkC2S's Avatar
my coolant leak is getting worst, so mine will be at RAC Performance monday..I'd replaced the cap & it still leaks..thought about replacing the tank myself but decided not to..too much of a PITA..
Old 10-24-2010 | 08:59 AM
carsareart's Avatar
carsareart is infamous around these parts
I have noticed I add about 1 or 2 ounces every 3-6 months into my overflow tank. I replaced my cap with an updated cap and tank 3 years ago. I have never seen a leak or drip....No overheating...Cleaned the radiators and combed the fins.
1999, 129,000+ miles, tip, autocrossed monthly, driven weekly.
Old 10-25-2010 | 01:10 PM
Tmainevent's Avatar
Yea I opted to go with factory cap...paid $21. From Porsche dealer around me. No issues since....put about 200 miles on it this weekend.
Old 10-25-2010 | 05:00 PM
Byprodriver's Avatar
Byprodriver is infamous around these parts
Mine did that also turned out to be hairline crack in 1 of the heads. Inspect your sparkplugs.
Old 10-25-2010 | 08:03 PM
carsareart's Avatar
bout time to change the plugs anyway. If I remember correctly a plug that has been burning water would be clean...is this correct?
cockneymike
10-22-2015 06:00 PM
agentsmurf
Cayenne 955/957
09-14-2015 01:46 PM
AuZZie
09-02-2015 04:26 PM
Quick Reply: Are coolant leaks somewhat normal?
