GT3 side skirts issue....
the car has the GT3 aerokit retrofitted to it and looks great but noticed that the side skirts do not sit flush with the car. They can easily pushed up against the side of the car like they should be but just don't hold there. You could fit a credit card or two in the gap between the skirt and the car.
On my previous 996, I also retrofitted the GT3 aerokit but everything looked great - didn't have this issue. But this car I just bought from FL. I'm thinking there may be some double-sided adhesive "tape" that I could use - I dunno - is there something in the retrofit kit that should've been put on to prevent this or does this happen a lot? Trying to figure out if it's something I can do or need to run by a high-end bodyshop....
Thanks for any help!
The skirts are secured with double sided tape along their length. If you can fit a credit card down the side your double sided tape has gone bad.
You probably need to remove the skirts and replace the tape.
here is a pic of what i'm talking about. i inspected the "crack" a little more closely and see that the adhesive is coming apart. any idea on where i can get more adhesive stripping???
What year is your car? Mine is 99 and had the same problem. Some of the kits did not get installed with a double sided tape. Porsche has a part that is more of a metal channel on the top side of the skirt that the skirt snaps into. I had to replace the channel as it was spreading. Fixed the problem and the part was like $50 a side. Not really a big deal to fix after we realized that it was a channel not tape.
Instead of the double sided tape holding the skirt it holds a metal channel that the skirt snaps in to. Basically a v shaped piece of metal. The metal fatigued over time and there was a gap on top of the skirt. Hope that makes sense, seems to be on the early areo kits
-Eli
Lowtush
01-25-2022 10:48 AM
