My Battery Blew Up!
Old 07-06-2007 | 01:24 AM
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
holy hell- that is lame!
how old was your battery?
anyone have link to the DIY thread for right type of Optoma battery to buy and how to mount it? I think I will do it as a precaution...
Old 07-06-2007 | 08:00 AM
UM911's Avatar
UM911 is infamous around these parts
About the age of the battery I am not sure because I actually just bought the car about 3 weeks ago so I have no idea (Skibums old car). I was able to put the Optima Yellow top in last night and all I have to do now is make the bracket for the battery so it does not slide around. Here is the link to the bracket I will make, https://www.6speedonline.com/forums/...ght=Optima+DIY. I will take pics when I am done making it.
Old 07-06-2007 | 08:09 AM
DaveMo's Avatar
DaveMo is infamous around these partsDaveMo is infamous around these parts
Just a thought. Bosch makes a replacement battery that is a perfect fit - including the breather hose - and is sold through Pep Boys. It runs about $115. If you can, it helps to briing the old battery along for sizing. It took the sales guy three attempts to bring out the correct one. Ten minutes later, I was back on the road.
Old 07-06-2007 | 08:58 AM
p0rsch3's Avatar
Thanks- congrats on your new purchase! Kinda sucks you we're 'greeted' with an exploding battery, but hey I guess the two of you are just getting to know each other.
Did you ask Skibum what he did in that car that might have put the battery in such a volatile state??
so is there only one 'Yellow Top' or are there variants with different CCA ratings?
Old 07-06-2007 | 06:08 PM
phaphaphooey's Avatar
phaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond reputephaphaphooey has a reputation beyond repute
if boxsters take the same battery there is an autozone and costco battery that fits and is around the 50 dollar range
Old 07-06-2007 | 06:22 PM
zdr2k's Avatar
zdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud ofzdr2k has much to be proud of
+1 on the optima......no acid worries.
DIY link here:
http://www.renntech.org/forums/index.php?showtopic=7072
good luck
Old 07-07-2007 | 08:10 AM
valmeida's Avatar
valmeida is infamous around these parts
Sorry to see that but glad to see yor car is ok.
Old 07-07-2007 | 04:25 PM
grahamtwatson's Avatar
grahamtwatson is infamous around these parts
I'd make sure I knew what the actual cause was before just replacing the battery - a couple of things could be a dead short across the terminals in certain circumstances or a more or less air tight battery compartment for some reason - charging batteries give of hydrogen.
Although it probably was a battery fault, better safe than sorry...
Old 07-07-2007 | 09:11 PM
PDL996's Avatar
PDL996 is infamous around these parts
Sorry to hear about your battery. I hope that you can get it cleaned up.
What is the best replacement battery? Optima Yellow Top?
Thanks.
Old 07-08-2007 | 09:58 AM
zdr2k's Avatar
Thanks.
For more info......
http://www.1st-optima-batteries.com/
I got mine from them.
Old 08-14-2009 | 01:16 PM
Brando's Avatar
Brando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud ofBrando has much to be proud of
Cool OMG.....Mind just did it too!
Guys.......this is a freaky story and I was afraid that I had fried my car!
But as it turned out, the stars were just aligned and it was a strange 1 in a million coincidence.
I just finished installing my new seats yesterday afternoon. I double checked all the wiring 3 times when I was done before inserting the key and starting the car.
Everything looked good.....I put the key in....and turned it......and BOOM!!!! I mean BIG BOOM.
Smoke is pouring out from under the hood....all electrics are dead.....I can't open the hood....and the car is in my drive under garage.
I'm freaking out!! Is it on fire? Is it going to burn the house down???
I'm thinking I have destroyed the complete electrical system in my car because of a pinched wire or mis connection.
Smoke finally stopped. I calmed down enough to remove the wheel and find the release cable.....looked under the hood and found this!
What are the odds that it just happened after I had installed my seats? But it was totally unrelated. My install was fine.
Got a new battery......old one was dated early 05. I had kept it on a battery tender which prob cooked down the water level. Everything is fine.
Check your battery!!
Old 08-14-2009 | 01:47 PM
Mother's Avatar
Mother is infamous around these parts
I heard a real loud bang followed by lots of smoke coming out from around the hood.
If you saw smoke! it was vaporized acid and it needs to be cleaned immediatley don't let it sit. I had one blow up once and the acid got everywhere. GL now I have a Opltima.
Old 08-14-2009 | 01:58 PM
Brando's Avatar
Cool
The plastic battery cover did a good job of containment.
I cleaned everything really well and then took a pitcher and mixed in baking soda and poured it over and into everything, cleaned it again and sprayed WD40 onto all metal and wiped it down.
Old 08-14-2009 | 02:02 PM
BavarianAudi's Avatar
BavarianAudi is just really niceBavarianAudi is just really niceBavarianAudi is just really niceBavarianAudi is just really nice
I wanted to purchase the optima battery but thought that it would keep dying out if i kept the car in accessory mode. I ended up getting a giant Bosch one. I just wanna know from your experiences how long can you keep it in accessory mode on an optima battery?
Old 08-14-2009 | 02:17 PM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
Originally Posted by CosmosC4S
Hey, I've used 3 Dell desktops (still using 2) and I've not had any problems with them. In fact, my next desktop will be another Dell.
I assume the Dell battery reference was to a laptop.
Quick Reply: My Battery Blew Up!
