Blinking overheat light when temperature is normal
You know, this is actually not that tough of a repair job as a diy. Its a bit of a pain moving stuff out of the way and getting the pesky hose clamps off, and then wiggling the old tank out of the way and the new tank in, but it is not that bad. There are a number of threads on renntech that I used as a reference when I did mine. Good luck.
If the job isn't too bad - I would think the dealer shouldn't have too much problem getting it done efficiently and quickly.
Yeah, the shop will have you up and running in no time. And no, dropping the engine is not necessary, although I've heard it makes it a bit easier to access everything. I've had to replace a coolant tank in my old boxster s (much harder to access in the boxster), and my c2. Good luck.
This is true, but if you want, I can take the motor out jk
Originally Posted by AsianImage
the cost for my expansion tank replace and install with all genuine Porsche parts and coolant was about $600.
Sooo...FWIW you can take that number with you as a gauge. Good luck!
Dang - owning this car is like having to take care of an old dog. I feel like I'm taking it to the vet all the time.
Originally Posted by sharkster
This is seriously eating into your PSS9 and Tubi fund lol!
I have no idea what to do with it after you guys fix the expansion tank.
