Mobile 1 5w40 oil = for diesel trucks?
I was going to buy oil and I saw the Mobile 1 5w40 in a 5 liter bottle. But on the container it states that this oil is for diesel trucks. Is there a difference between this and 5w40 oils for regular cars?
Originally Posted by icemann633
Tell me what the difference is?
According to Mobil1 website, the one for Turbo Diesels has a special additive for diesel engines and the oil is for turbo diesels. It was designed to dela with the special needs of Turbo Diesels in extreme conditions...so why put it in a gas engine? If it was ok...then it would say for gas and diesel engines right? It was approved for DIESEL USE.....
Originally Posted by WARDHOG
I know Porsche has two types of oil weights recommeneded and 5W40 is one and the other is 0W40.
Mobil1 calls some oil's for high mileage engines but that doesnt mean it isn't good for certain engines with low miles.
I use 15w-50 anyways
Interesting...Im not saying he should use it, Just wondering if it was a marketing scheme.
Page 171 out of my MY2003 Owner's Manual
Engine Oil Recommendation
Recommended oil viscosity ranges dependent on ambient temperatures:
Ambient temperature SAE Viscosity Range Ambient temperatures SAE Viscosity Range
(seasonal) Mineral oil based (seasonal) Synthetic oil based
engine oils engine oils
generally higher than 15 W-40 generally higher than 10 W-40
50°FjlO°C 20 W-50 50°FjlO°C 15 W-40
20 W-40 15 W-50
generally lower than 15 W-40 generally lower than 10 W-40
50°FjlO°C 10 W-40 50°FjlO°C 10 W-30
10 W-30 5 W-30
generally lower than 10 W-30
14°Fj-1O°C 5 W-30
Use only engine oils labelled as API SH or SJ, or ILSAC GF 1 and viscosity grades of SAE 10 W-40 or higher.
Preferably you should use synthetic or semisynthetic engine oils.
If in doubt ask your authorized Porsche dealer for Porsche tested and approved all-season oils.
and some of page 172
The efficiency of an oil is expressed, for
example, by the API, ILSAC or ACEA classifica-
tions.
Use only engine oils with the classification API
SH or SJ, or ILSAC GF 3, or ACEA A3 (Europe).
20 W-40 15 W-50
10 W-30 5 W-30
14°Fj-1O°C 5 W-30
tions.
Huh????????
20 W-40 15 W-50
10 W-30 5 W-30
14°Fj-1O°C 5 W-30
tions.
20 W-40 15 W-50
10 W-30 5 W-30
14°Fj-1O°C 5 W-30
tions.
I'm running the 5W-40 for turbo deisel engines in my car. Runs just fine, engine even idles a little quieter. The oil is also rated for gasoline engines, read the back of the bottle. It qualifies under Porsche's specs in the manual.
I haven't had any issues with it and will probably continue to run it. I will change it every 5K miles.
