Work Vs-XX on a 997 TUrbo
The wheels are beautiful. The mesh design is classic to me. Looks good now and in 10 years. My question is concerning their construction and weight.
I am not 100% sure but I thought they were not forged wheels and consequently become heavier. I think the centers are cast design. Can someone who knows for sure respond?
The Rennworx wheel are forged. The Work wheel is made in Japan I believe.
I would like to know definitively.
Thank you
Thank you
Thank you
Thank you
-work brombachers are cast wheels and my 19x12s in the rear weigh about 28lbs
-my fully forged oz superleggers 3s in the same size weigh about 27 lbs
-rennworx is just a brand name slapped onto work wheels
-techart wheels, i believe, are also made by work wheels and their ever popular formula wheels are cast and are heavier than the work brombachers in teh same sizes even though the work broms are three piece wheels
-being cast doesn't make a bad wheel and being forged doesn't make a good wheel, stick with a quality brand and you'll be fine
-it's a balancing act just like many other things in life - if you want great looks and lightweight... well for me, there's nothing better looking on a porsche than a two, three piece wheel with mesh centers a la brombachers. if i wanted ultimate lightweight from a quality brand i would've gone with champions, but they don'tlook as "sophisticated" and involved as your BBS LMs, Brombachers, OZ3s of the world. why? they're kinda one dimensional since they are one piece, yet they are light.
-the most important decision on wheels is do they truly fit? many people don't own wheels that truly fit the car. many run narrower widths or resort to spacers. or they rub when lowered. that's not true fitment to me. my car is lowered to 0 finger gap and the wheel edge runs very close to the edge in the rear and as much as possible in the front - yet i don't rub period. i run 315/25/19 PS2s and again don't rub. why? because they fit and i appreciate alan baylis' help in this regard. i trusted his specs and it worked out fine.
there certainly are a lot of options out there, but if you really put the test to the wheels, many fall short. the work broms do work for the car and if you plan on tracking your 911, you should have a set of dedicated "track" wheels anyways since you probably want a smaller diameter not just for weight savings but for better tire selection.
do your homework before you spend your heard earned dollars. way too many crap wheels i've seen on 911s here and elsewhere, but hey, ignorance is bliss?
Work Brombacher - different center than VS-XX. FWIW
Ben is correct, Bill/Rennworx sells Work Wheels under the Rennworx name sans the Dymag stuff.
The Brombacher is a cast wheel as is the VS-XX.
Uhh, that's what I said. But then again, what do I know about Work wheels? I've only been using them since 2001, I'm only an authorized dealer, and I was only at the N/A distributor during lunchtime.
I have been using them for a while as well
yeah al dont know ****...
first and one and only work equips on a porsche o.g. baybee.. thanks AL!
