What Type Of Oil?
What would happen if you "overfill the sump"? How would you know? I drove it after I put in the 2 quarts and it did not smoke or feel like anything was wrong.
Damned if I know, but did you check the level again after having driven the car up to full operating temperature. Read somewhere that no good can come from an overfill of oil. Overfilling a regular engine results in the crankshaft splashing the oil around in the pan beating into a foamy bubbly froth. The oil pump starves out trying to pump bubbles and damage occurs.
![hilarious](https://www.6speedonline.com/forums/images/smilies/smLach2.gif)
What were you doing to your car babying it for it to consume 1 qt at 2,200 MILES!!!
![EEK!](https://www.6speedonline.com/forums/images/smilies/eek.gif)
Hi,
some pretty reasonable prices for the -40 there. Just been to a car shop here in dubai and its selling for almost 45 USD for 4 litres. Have the chance to get to the states from time to time. Do they sell it in Costco ?.
Rgds.
Rgds.
The Costcos around where I live don't sell it. In fact, they don't even stock 5W oils of any kind - only 10W oils. Plus, the only oil I saw was from Chevron/Standard Oil. Blech!
Dubai, UAE is awesome!!! I was just there 2 months ago.
I have 450 miles on mine and the first bar was open (below the line), I just put in 250ml and the bar is now full with the excess bar open still. On my 996TT- Speed Gallery did the oil changes and they always had the oil above the measuring line (bar above the line filled). What about on 997s?
Anybody tried Motul 300V 5w-40? It looks pretty good:
Racing lubricant for racing cars
100% Synthetic – Double Ester Technology
TYPE OF USE
Racing cars with atmospheric or turbocharged engines, race engines operating in a wide range of rpm
and temperatures : race on tracks, single brand races, rallyes, uphill races…
Engine producing medium fuel dilution in the oil.
Other applications : Gasoline or diesel engines, turbocharged, direct injection and catalytic converters.
PERFORMANCES
STANDARDS Above existing standards.
Reference team SUBARU WRT, World Rally championship –
Graff Racing, Formula Renault (open wheel cars, single brand race)
Double Ester technology : maximum oil film resistance, balanced polarity, resistance at very high
temperature.
Friction Modifier : maximum power output, decrease operating temperature.
0% shear loss : Stable oil pressure whatever using conditions.
Maximum anti-wear resistance.
Perfect engine cleanliness.
5W-40 grade allows excellent oil flow into the engine, fastest oil pressure set up, faster rev raisings and
at the same time high oil pressure at high rpm and high temperatures.
RECOMMENDATIONS
Oil change : according to your own use.
Can be mixed with synthetic or mineral lubricants.
PROPERTIES
Viscosity grade SAE J 300 5W-40
Density at 15°C (59°F) ASTM D1298 0.905
Viscosity at100°C (212°F) ASTM D445 13.8 mm²/s
Viscosity at 40°C (104°F) ASTM D445 80.8 mm²/s
Viscosity Index ASTM D2270 176
HTHS viscosity at150°C (302°F) ASTM D4741 4.51 mPa.s
Pour point ASTM D97 -36°C / -33°F
Flash point ASTM D92 216°C / 420°F
TBN ASTM D 2896 10.9 mg KOH/g
TYPE OF USE
PERFORMANCES
temperature.
RECOMMENDATIONS
PROPERTIES
