My new 997TT w/Twin 30R's...
#346
we have reached the desired power levels of this project. i want a true daily driver that i can pump in 93 octane pump gas and produce 800 - 850 crank horsepower (700 - 750 rwhp). also, there will be a race program file which will produce 900 crank horsepower (800 rwhp) for occassional weekend or track use. tym has successfully reached 800+ rwhp on race gas. he is now working on the drivability. when this is completed, he will turn it down to hopefully make 700 - 750 rwhp on 93 octane pump gas. this will be the ultimate true daily driver! the car made 800+ rwhp so easily that tym feels we can easily reach 900+ rwhp when the internals are done!
#347
Congrat - amazing stuff - I just cannot believe that a stock motor can handle these numbers. They still say that the 996tt motor is done ayt 600 ~ rwhp and the 997tt motor is that much stronger
#348
tym said the 997 motor is superior than the 996 motor. the 800+ rwhp on race gas was reached with a very conservative tune. tym feels confident that we should easily hit 700 - 750 rwhp on 93 octane pump gas!
#350
Yes....
2001 996TT 3.6L and stock ECU
#352
It depends on what chassis dyno you are gauging the crank hp on.If its a dynojet ....well then several 996,997 make 700 crank hp on pump if its on a mustang well then there are only a few that make 700 hp on pump.I do know of one or 2 that makes 700 hp @the wheels on pump...both 996's and both with built motors....one of them is on a Mustang.
#353
#354
Im not sure if you mean mass produced but then I don't know of anyone that sells it as a PUMP kit... they rather sell it and market it as a race (high HP) kit... more like a 850 HP set up...
my point is....
One has to get somewhat custom to achieve these numbers and most P cars with a GT3076R or a GT35R will produce 700hp crank at .8 bars bars...
It would not make sense for a tuner to make all this custom stuff and market it as a PUMP gas file.... they rather sell it as a higher boost set up.... and that makes sense becasue that's what we are looking for...
Evoms uses a flashloaded between pump and race gas...... Others use Boost controllers... but we all achieve the same goal....
#355
I have not seen anyone offer BOLT ON packages at those levels as most are interested in what the race gas will produce... another 100 rwhp.... and that requires motorwork.
#356
just wondering as i will be using my car as a true daily driver. i want the ability to pull up to the corner gas station and pump 93 octane gas and still make over 800 crank hp. And for occassional weekend or race use, i can flip a switch to race gas mode, pump in the race gas, and make 900 crank hp. Personally, a bolt on 800 hp kit really appealed to me since i want to put 10K miles per year on my car.
#357
I just want to be sure we are talking 700 CRANK hp?If so I would think 700 crank is available from several tuners.Here is one example https://www.6speedonline.com/forums/...o-results.html on a Mustang dyno @ all 4 wheels is making 570,depending on the conversion used is pretty close to 700 0r about 684. Put it on a dynojet and it will make 700.This is just a regular GT700 ....add intercoolers and a few other odds and ends and it should get there pretty easy.I believe AWE is claiming 700 crank on pump gas on their 997and I am sure Proto will achieve this as well.If it is 700 at the wheels you guys are talking about well that is a different story.Nonetheless Switzer is making impessive power with your car.Joe
#358
#359
O.K. got ya .....bolt on .....Pump gas.....I don't think so.
