Stealership Stole My Fabspeed Exhaust?
Do the Fabspeed cat bypasses (cat deletes) set off CEL's?
Thanks alot....
Thanks alot....
I guess we need more information. Is this your car - if so, how do you not know what's on it. Did you buy the Fabspeed bypass kit or just the Fabspeed V3 exhaust system? Check here and let us know what you have. http://www.fabspeed.com/997TT.html
cat deletes will generally set off a CEL......you need a bypass
I've had a dealership steal aftermarket bushings off of a car.......didn't realize it for 3 months when I put the car up in the air to do some work.
I seriously doubt they would take your bypass pipes off and install new cats esp under warranty. If they did anything like that, they would have charged you for sure. Your sig says that you have Fabspeed stage 2. Is that an ECU flash or is it referring to your exhaust? Maybe they reflashed your ECU back to stock to get rid of the CEL.
joseph_number1
07-19-2018 05:45 PM
Fabspeed Motorsport
Audi
08-21-2015 11:30 AM
