to pccb or not to...
...I did not chose the pccb option,should I have?
I will not be tracking my car but will be doing a lot of driving on country roads in Europe this summer.
Do the steel brakes rust easily,and how much does that detract from the appearance of the car.
I m sure this has been discussed many times,but I just wanted people's latest opinion on the matter.
Thanks for your understanding and advice
I doubt people's opinions have changed much. Are you worried about performance, appearance, or both? The steel rotors on the current 997TT are probably the best that have ever come out on a 911 turbo. Yes they will rust, but when you drive, the friction should wear the rust away. Yes they will make dust, but believe it or not, so do the ceramics (just a lot less.) In the wet, they are probably better than the ceramics.
If you are worried about performance, there are brake systems available in the aftermarket...Brembos are very very good.
When making the decision, I felt that the cost was high, but they are one of the few options that work very well, and retain value when selling or trading.
I am thinking more of performance,and if the steel brakes are better under the rain:I will keep them,cause it has been known to rain often in France...
Thanks for the advice
If you have the money go for it. They are fantastic. You will not regret it and will want them on every vehicle you own in the future, The brake dust is negligable and rust is non- existent giving the car a much cleaner look not to mention better braking performance.
Regards,
Peter
Regards,
Peter
From rennteam.com
I remember folks quoting WR regarding big reds. Saying that if they are good enough for Walter Rohrl they're good enough for them. But have a look at his comment in May's GT PORSCHE:
Chris Harris: "What are your thoughts on PCCB"?
WR: "First I thought it was too expensive then I had it first on a 996 GT3 which I used for one year and did 30,000km. Just before I let the car go, I took it for a service and they said the brakes were like new. But then I go very gently with the brakes and since then I always have PCCB. The car rides much better & you can feel the weight not being there"
I've tried to explain the same thing here a few times. PCCB's are an expensive option but they cost less to maintain over time then Reds do. Porsche recommends changing steel rotors w/ every pad change. Some guys (depending on how much of the pad they've used) wait for every other pad change. My Porsche dealer wont cut rotors. But w/ PCCB's you could go a loooooong time without needing to change rotor's (as long as you dont bust one from doing the wrong thing that is). I've seen info. from sources that say way in excess of 100,000 miles. As high as 185,000 miles before needing to change the rotors. Of course that all depends on the type of driving you do. Tracking the car all the time would deminish that quite a bit. Even if you need a dozen or so steel rotor changes & no PCCB's rotors I doubt it ever completely even's out $ wise, you're not going to re-coupe the $9k cost for PCCB's by not needing to change them but still worth considering imo.
But I just felt that was interesting that Walter Rohrl always gets PCCB's now. Guess the Red's arent 'good enough' for Walter any longer.
Upgrading tp ceramics will cost more than its worth and my feeling is that if you did not get them on your car right out of the gate ---let it go . The steel brakes are amazing too .
I have had both and prefer the ceramic but I bought a Turbo off the showroom floor and I was lucky at the time to get one .It did not have ceramics .
if you are not going to track the car...the only advantages are less dust and appearance...don't think that is worth the price of admission...on the other hand...they are a lot cheaper to order new with the car than they are to put on later...
My first 4 Porsches did NOT have ceramics. It was until I bought my 05 996tts which came standard with ceramics. Till then my next 2 997tt have had ceramics and I LOVE them. Not only do they feel better, but IMo they look amazing!! I love the ceramics.
DO IT!!
DO IT!!
On my third Porsche with ceramics. I bought a 997S Launch car off the floor and it came standard with ceramics. Didn't really know much about them at the time. Now, I would not order a P-car without them. On my secong 997 Turbo and custom ordered both with them. Only minus is they can be a little tricky when wet.
