Lowering springs, adequate amount but not excessively low...any suggestions?
#31
Just ordered the springs this week. Thanks.
#32
Springs, sways, and I believe the dog bone kit. I might be missing something, will post everything it includes the minute I get the quote back from Fabryce.
He said the springs and sways are doable on their own but highly recommended the other stuff due to crap factory bushings deflecting etc. Not probably missed on a street driven car but would come into play the harder you push it.
Im just doing the whole thing to save me going back a 2nd time later on! You know how mods are.
#33
#34
ok, talked to Fabryce, car is scheduled in Wed morning. More than likely go with level 1* for now, thats what he quoted me on. Will drive it around and report back later in the week.
*(thats springs, sways and of course alignment).
#35
At slower speeds I actually like the GMG springs in sport mode as the feedback is heightened but not too bumpy. There has been a few instances in sport mode at higher speeds (130+++) where the car was almost too bouncy. This was due to poor or uneven roads and that is where the non sport mode really shines.
Of course coilovers would be the best option but for those who dont track their car but still like to push their car on the street, the GMG springs have been very good to me. And of course the price difference is huge but that should not be an issue when dealing with a 140k car. Its really just boils down to how hard one pushes their car.
#37
gmoney,
I plan to do the exact same for my car. Fabryce has recommended to me full stiff for rear sway, full soft for front sway, is that what you plan to set yours to?
I plan to keep all alignment settings stock, EXCEPT for front camber. Stock front camber is -.4, some of the more knowledgeable people like eclou has theirs set at -1.2 so that the car doesn't push so much in corner. Do you plan to increase negative front camber?
When I spoke to Fabryce, I forgot to ask what exactly the alignment settings for their demo turbo are, at least as far as the front and rear camber settings (the other two parameters, toe and caster, shouldn't change much from stock AFAIK). If you do find out from Fabryce, please post. (I'll ask him to when I drop off the car.)
Vic55 (hi), if PSS10 is what you are talking about, I believe the GMG springs are actually stiffer than PSS10's springs. In that sense, maybe the 2 are just different from each other, not worse or better?
#40
Here's a good pic to show you the new ride height with H&R's. The ride is great, slightly stiffer than stock, but maintains a lot of the good characteristics of the stock setup while adding a nice sporty look and feel.
#41
FYI I went with what Fabryce recommended- aggressive non track set up.
#44
You are welcome. Obviously complicated issue, but I've read up a lot on what people do and those 2 parameters (sway bar settings and front camber) I mentioned are the only ones that are relevant, AFAIK.
I had my sway bar installed already but have not yet decided on Bilstein PSS10 vs. GMG spring. I am leaning more and more towards Bilstein.
