guys any one tried ASR intake system ?
I will tell you guys this. Anything from ASR Engineering will be a great product (mod).
The work he's done for the M5/M6's has been outrageous and make REAL horsepower. He's the reason why my E60 M5 has run an 11.65 sec. 126 mph trap in the 1/4 mile. 2nd fastest is US as per Dragtimes. The #1 E60 M5 was also built by ASR.
You will never go wrong with ASR.
Cheers, GT3Ranger
Cheers, GT3Ranger
Bottom line you doubt the ASR products well then do not get them.
It is a simple as this. Do not get it! The result is simple... you lose.
Cheers, GT3Ranger
Cheers, GT3Ranger
you mean this intake that ASR "engineered " .lol. over tow years ago at Fabspeed.
http://fabspeed.com/997TT_18.html yes heat soak heaven .
The Werks seems to be much Higher Quality & higher in HP #'s.......It looks to really work when your 60mph+ All the COLD air is rushed straight into the intake. Were on the ASR the COLD air is lost and gets thrown in the HOT motor to end up getting heat soaked by the time it reaches the air filter
factory box is good for LOTS of HP and more than enough to handle a stock turbo car with GIAC or similar and exhaust.
Most, if not all, of these intakes are more cosmetic. If you want to brighten it up in there consider GMG or Werks one carbon units.
