Garrett bolt on 997 TT
#76
He should have used a non ribbed hose... I now cause I had the FVD one...
![](https://www.6speedonline.com/forums/signaturepics/sigpic3357_8.gif)
2001 996TT 3.6L and stock ECU
#77
![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
#78
You will need at least additional electronic boxes for wastegate control to drive them with stock ECU
But 997tt ECU cant controll wastegates directly like on 996tt. These cars(997tt) have turbines with ECU controled by cables stepper motors what drive VTG actuators to adjust boost level, to control wastegated turbos you need electronic boost solenoid what can controll amount of boost going to wastegate actuators, these two principles are a lot different ![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
Are you sure that there is enough space between body and engine to fit these pipes ? Btw such soft pipes are not so good idea because they often crack and turbines suck air before AFMs so engine parameters are out of control if the pipes crack. We here 9ff 997tt car and 9ff use such soft pipes, in that car they both cracked and car run like sh..t before we repair them with new ones custom made by aluminium, that is more good and reliable idea i think![Wink](https://www.6speedonline.com/forums/images/smilies/wink.gif)
Btw i cant reply to your PM because i am to young user here yet, need to have at least 15 posts to reply PMs
![Smilie](https://www.6speedonline.com/forums/images/smilies/smile.gif)
yes, you right. I have small pierburg box.
there is also special device responsible for changing the frequency to communicate with something.
![Confused](https://www.6speedonline.com/forums/images/smilies/confused.gif)
Yes there is enough space, we know where is the problem.hmmm....9ff they use different one, I believe you have a problem with them.
![Mad](https://www.6speedonline.com/forums/images/smilies/mad.gif)
Show me please your aluminum ones.
![Big Grin](https://www.6speedonline.com/forums/images/smilies/biggrin.gif)
#79
any chance for the pictures of your pipes, soon I will show mine
#81
I think i have pictures to that pipes what we made but check and cant find them, anyway they havent nothing to compare with your pipes, your looks sweet, our are only for problem free work because 9ff pipes crack a lot
But if i found the pictures in any of my computers i will send you them no problem
04-28-2022 12:38 AM
Rez90
08-24-2015 09:53 PM
pwdrhound
08-23-2015 07:36 PM
johnny.dangerous
08-21-2015 10:48 AM
