Pics & Review of My Bilstein PSS10 Lowered Red Turbo
#512
Can,
I have a set of RE-11s and getting a set of R888s. I have a similiar alignment as you in terms of camber. I'm feeling I need more. I corded my H6s with such a minimal camber. I was going to try and get -2, I have techart springs. Should I be able to get close -2 without camber plates and adjustable arms and such?
I will leave the backs in -1.5 range
For rear camber: I've been told that stock rear camber could be adjusted to minus 2 range, up to minus 3 in fact (anyone pls correct me as needed), without any hardware change.
For street driving, IMHO -1.2/-1.6 is fine; "camber is for cornering," too much camber hurts straightline braking and acceleration.
For the track, in general, I've seen minus 2 range both front and rear.
For others reading this and wondering why negative camber is needed: The faster you are in corners, the more body rolls, and as body rolls, tires lose contact patch area (not good), there are 3 ways to counter this:
a. Increase spring stiffness
b. Increase negative camber
c. Lower the car
Body roll and weight transfer are major enemies of handling goodness (this is why weight is mother of all bad things in motorsports, weight causes increase in body roll/weight transfer). This is also the reason why the track junkies on this forum have such stiff suspension and huge negative camber in their cars.
Regarding how much camber, sure start with what you see and see how you like it; it is an easy thing to change. There are 2 ways to see whether your camber settings are adequate for your driving:
a. Tire wear
b. Tire temperature
If outside wears more, or outside is hotter than inside, then you need more negative camber. The more advanced you are as a driver, meaning more speed in corners (corners separate the men from the boys ) , the more neg camber you are going to need. Hope my rambling is somewhat helpful.
#514
Cannga,
Ran my TTS on the track after the Damptronic coilover and H&R sway install and it made a dramatic improvement in the handling. I am very happy with the overall results.
Here is a session I taped.
Walt
Walt
#516
Cannga,
Motorsport Ranch Cresson, Texas 1.7/ 2012 997 Turbo S - YouTube
Walt
Walt
#517
BTW, what's interesting about this run is that if you look at the video, driver wasn't Walter Rohrl. Apparently 3 drivers were involved, Porsche test drivers Walter Rohrl and Timo Kluck, and Porsche factory driver Marc Lieb, but ultimately it was Marc Lieb who was fastest. Maybe age has finally caught up with the master .
BTW, I've looked but cannot find definitive confirmation what tire was used for this run, does anyone know whether it was Michelin Cup R comp tire, same as stock? There is also rumor that the car goes even faster with racing slick, at 6:49!
http://www.motorauthority.com/news/1...leife-lap-time
In case you missed this from the best sports car company in the world :-) - holy cow it's sub 7:00!!!
http://youtu.be/Bc9UUPNaOzE
#519
I would still say the main stay of suspension mod are in order of importance: stiffer spring/coilover, sway bar, then those links with solid heim joints.
#520
Sanham, for what its worth, I run one on my TT. I have actually had one on every Porsche I have ever owned. I consider it a required "must have". More then likely because it was very noticeable when I installed it on my first 87 911. That and springs have always been my first suspension upgrade steps, then thicker sway bars. Baby steps...
#521
#523
Champion did have one installed on my vehicle when I took delivery. However, it was upon my request. CMS installed an aluminum FVD shock tower brace. I had requested a Carbon version but the diameter was a bit larger and would not clear some of the body parts/battery; I believe.
The diameter of the FVD is half that of the one I had on my 993 (carbon). I recall the brace on my 87 had some girth to it as well.
#525
At 50% off you can't go wrong and these are a very easy DIY. Seeing as your install will be "fresh" you can offer us before and after comparisons if any are detected.
I have had mine in since day one, therefore cannot offer any real feed back one way or the other; plus my suspension development has grown over the years with the stock tower brace in place every step of the way. No one has ever suggested removing it through the development process...
